Can You Build a Compact Beeping and Vibrating Radio Receiver at Home?
Building a compact beeping and vibrating radio receiver at home is feasible but presents several challenges. The receiver can be designed to vibrate and beep by integrating a vibrating motor and a speaker. However, adjusting the transmitter for various distances is complex due to numerous variables affecting signal travel. While small receivers can be made to fit on key rings or phones, achieving the necessary compactness and functionality may require commercial production rather than a DIY approach. Additionally, power consumption is a significant concern, as even small devices tend to drain batteries quickly, complicating the project further.
lightwait
First, I know nothing at all about this topic, which is why I'm looking for help. I'm interested in building a radio transmitter/receiver like a child locator at home. The difference would be I'd like the receiver to beep rather than the transmitter, if that's even the correct language to use. For example, if your kid (or cell phone, briefcase, etc.) strays too far, your transmitter automatically beeps and/or vibrates at a certain distance. I'm trying to find out the following questions: 2. How to have the receiver both vibrate and beep. 3. Would it be possible to have the transmitter be adjustable to various distances. 4. How small could the receiver be? 5. How much it would cost to build this at home, using the smallest units for each .Essentially I'd like the receiver to be able to fit on the back of a phone, key ring, etc., and the transmitter to be similar in size. I understand this is a lot of information, so any help is greatly appreciated, I'm at square one right now. Thanks in advance.
hi lightwait
welcome to PF
Thats not a problem
no as there are too many variables that determine a distance a signal travels
event where there are no objects to reflect and absorb the radio signal even a very low level signal say 10mW ( milliWatts) can travel 100's of metres or more
you could have the unit small enough to be on a key ring ... those already exist for use as key finders
The major design problems are the small size required, its not likely to be able to be done as a home project. Most radio technicians would not be able to produce the required circuitry small enough to do that. ie woould probably need to be commercially made
The biggest overall problem wouold be powering the TX and RX units, even those lost key finders chew through batteries very very quickly. That really is what makes it impractable
There are small transmitter and receiver units out there likehttp://robokits.co.in/shop/index.php?main_page=product_info&products_id=75 units They are easy to use but still require other electronics around them to produce a functions system to meet requirements
Dave
Would the child be wearing the receiver? Or the transmitter?
The child, or in the instance I'd like to try- cell phone, wallet, etc. would have the receiver. So whenever the receiver reaches a certain distance you would be alerted. Thanks for the reply davenn, that's very helpful for pointing me in the right direction.
Hello,
Thank you for reaching out for help with your project. Building a homemade radio transmitter/receiver can be a fun and challenging project, but it is important to proceed with caution and ensure that all safety protocols are followed.
To answer your questions:
2. How to have the receiver both vibrate and beep: This can be achieved by incorporating both a vibrating motor and a speaker into the receiver. The motor will produce the vibration while the speaker will produce the beep sound.
3. Would it be possible to have the transmitter be adjustable to various distances: Yes, it is possible to have an adjustable transmitter. This can be achieved by using a variable resistor or potentiometer in the circuit. This will allow you to adjust the distance at which the transmitter will beep or vibrate.
4. How small could the receiver be: The size of the receiver will depend on the components used and the complexity of the circuit. It is possible to make a compact receiver that can fit on a phone or key ring, but it may require advanced soldering skills and careful placement of components.
5. How much it would cost to build this at home, using the smallest units for each: The cost will vary depending on the components used and where they are purchased. It is important to research and compare prices to get the best deal. Additionally, it is important to consider the cost of tools and equipment needed for the project.
In conclusion, building a homemade radio transmitter/receiver can be a fun and rewarding project. However, it is important to have a good understanding of electronics and follow safety protocols. I recommend doing thorough research and consulting with experienced individuals before starting the project. Good luck!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
