Can You Turn a CUBE on a LATHE?
  • Thread starter Thread starter OCR
14 replies · 3K views
OCR said:
Yes.
But it will require mounting six times, once for each face.
1. You can hold the cube in a 4 jaw chuck, then face the end with a tool in the cross slide. Since the centre is not important, depending on what shape you start with, you might hold the work in a 3 jaw chuck.
2. You could clamp the cube to the cross slide, then face it with a cutter held in the chuck. But that would be more difficult to set up for accurate angled corners.
The example shown in the video shows multiple passes of a fly cutter. That suggests it was clamped to the cross slide, but more probably faced in a small milling machine.
  • Haha
Baluncore said:
Yes.
But...
Not sure if Baluncore is deadpan riffing on joke, or
What I saw was: A lathe. With a cube on it. Being turned.
  • Haha
Repeatably, again and again.
The example cube that turned up on the lathe was not turned up in the lathe.
How could I miss the opportunity to deliver deadpan, a couple of other obtuse ways it could be done, but in, not on the lathe. Can a lathe have obtuse ways, or is it only me ?
  • Haha
Thought so.
  • Haha
Yes, it is possible. See "machining a cube on a lathe" by machiningmomentsbrad on youtube.
Yes, we know.
It’s not as convenient to produce a ball on a vertical milling machine.
  • Haha
But it is very easy to turn a ball on the bed of a vertical milling machine.
A ball or a cube can be produced pretty much anywhere a magician turns up to remove the cover.
  • Haha
Machining a ball on a milling machine is functionally identical to machining a cube on a milling machine, except the number of remountings required is somewhat larger.
A tow ball can be made in one setting.
At most, only one remount is needed for a full sphere.
Mount the workpiece in an indexed head, with axis at a slope to the bed, or head tilted.
A single point cutter, offset by slightly less than the ball radius is mounted in the spindle to cut a circle on the ball surface.
While spindle turns cutter, slowly rotate the index head until you have a sphere.
Some interesting (and typically PF) responses here. :wink: I hope you all enjoyed that bit of nonsense.
It's largely a matter for definition, imo. If you put a morse 3 taper lathe chuck into the spindle of my toy vertical milling machine (and lay it on its side?), you've got yourself a lathe, afair. It could be argued that the workpiece rotates in a lathe and the cutters rotate in a mill - hence my use of the word "convenient".
