Capacitor voltage at time = infinity
The discussion centers on determining the voltages Va and Vc in a circuit with a capacitor that has been in a steady state for an extended period. It is established that the capacitor behaves as an open circuit to DC, resulting in zero current through the resistor and a voltage across it of zero. The correct voltages are Va = 0V and Vc = 80V, which aligns with Kirchhoff's Voltage Law (KVL). The confusion arises from the initial assumption of the voltages, which does not hold true under KVL constraints.
  • Understanding of Kirchhoff's Voltage Law (KVL)
  • Knowledge of capacitor behavior in DC circuits
  • Ability to analyze circuit diagrams
  • Familiarity with voltage calculations between circuit nodes
  • Study the behavior of capacitors in DC circuits, focusing on steady-state conditions.
  • Learn advanced applications of Kirchhoff's Voltage Law in complex circuits.
  • Explore the impact of switches on circuit behavior over time.
  • Investigate transient analysis of circuits involving capacitors and resistors.
Electrical engineering students, circuit designers, and anyone involved in analyzing DC circuits with capacitors and resistors.
new_id_7
I am trying to understand how to get the voltages Va and Vc in the following circuit.
It is assumed the circuit has been like this for a very long time.
Kirchoff's voltage law
So I know that the capacitor acts like an open circuit to DC. The current through the resistor is obviously 0, so the voltage across the resistor is also 0.
I redraw it like this ( easier to visualize for me ).
Now, I have the answer from my book to be that Va is 0 and Vc is 80. This allows KVL to work.
How do you know that Va is not 80 and Vc is 0? To find the voltage between nodes "a" and "b" I usually do Voltage @ a - Voltage @ b (using correct signs). Doing this between the top of the 80V source, and the top of the resistor gives: Va = 80 - 0 = 80. If I do this at the bottom, I get Vc = 0 - (-80) = 80. Obviously this is wrong because KVL won't hold.
Thanks for any help
Thanks for any help
There must be a switch opening or closing in this problem, or it makes no sense. Was a switch closed at time t=0 across that gap or something?
Ya, thanks I think I figured it out. I tried to simplify the problem by leaving the switch out, but that let's you figure out the voltage.
What I didn't tell you was that the switch causes Vc to be 40V before and after 0.
Then, I just think that no current can flow through the capacitor, so 0=I=C dv/dt means dv/dt = 0. Therefore, Vc does not change as t goes to infinity. Thus it remains at 40V.
If there is another way of thinking about it please let me know.
Thanks
