Capacitors in Series: Find Q on 1.0 μF Capacitor
  • Thread starter Thread starter sgoeke
    Capacitors Series
In the discussion, two capacitors, one with a capacitance of 1.0 μF and the other with 0.50 μF, are connected in series to a 100 V battery. The correct method to find the charge on the 1.0 μF capacitor involves calculating the equivalent capacitance using the formula 1/C(equiv) = 1/C1 + 1/C2, which results in the correct charge when applied with the total voltage. The charge across each capacitor in series is the same, and the voltage across each capacitor is inversely proportional to its capacitance. This understanding is crucial for solving series capacitor problems accurately.
  • Understanding of capacitor behavior in series circuits
  • Familiarity with the formula for equivalent capacitance: 1/C(equiv) = 1/C1 + 1/C2
  • Knowledge of the relationship between voltage, charge, and capacitance: V = Q/C
  • Basic concepts of electric circuits and voltage division
  • Study the derivation and application of the equivalent capacitance formula for series capacitors
  • Learn about voltage division in series circuits and how it applies to capacitors
  • Explore practical applications of capacitors in electronic circuits
  • Investigate the effects of different capacitor values on charge distribution in series connections
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in series circuits.
sgoeke
Two capacitors with capacitances of 1.0 μC and 0.50 μF, respectively, are connected in series. The system is connected to a 100 V battery. What charge accumulates on the 1.0 μF capacitor?
For capacitors in series: 1/C(equiv) = 1/C1 + 1/C2
V = Q/C
I used the second equation (V=Q/C) to find the charge with V = 100 and C = 1x10^(-6) but I did not get the right answer. However when I found the equivelant capacticance and used that in the second equation to find Q I got the right answer. Can anyone explain whey the second why to do this problem is the correct way?
Because there are two capacitors in the circuit.
If you use C=C2 (1e-6), then you are just considering a circuit having *one* capacitor.
You basically need to find C to see how the capacitance is split between the two capacitors. That would also give you how the charge is split.
With two capacitors in series you will end up with separate voltages across each, summing to the total voltage (100V). FYI, the voltages across capacitors connected in this way go in inverse proportion to their fraction of the total capacitance values. So if C1 and C2 are initially discharged and placed in series, when 100V is applied you end up with
Vc1 = 100V * C2/(C1 + C2)
Vc2 = 100V * C1/(C1 + C2)
Another feature of capacitors in series is that if you try to push a charge in from "one end", it pushes the same amount of charge through to all the capacitors along the line. That's why you obtained the correct answer when you used the equivalent capacitance and the total voltage; each of the capacitors is holding the same charge as the equivalent capacitance.
Ceq = 1/(1/C1 + 1/C2) = C1*C2/(C1 + C2)
Qceq = 100V * Ceq = 100V * C1*C2/(C1 + C2)
Qc1 = 100V * C2/(C1 + C2) * C1
Qc2 = 100V * C1/(C1 + C2) * C2
All the same.
  • · Replies 18 ·
14K
