How does the Capstan Law Determine T1 and T2 When the Capstan is Rotating?
  • Context: Undergrad
  • Thread starter Thread starter physea
    Forces Law
The discussion revolves around the Capstan Law, specifically how to identify the tensions T1 and T2 when the capstan is rotating versus when it is not. Participants explore the definitions of load and effort in various scenarios, including the implications of different weights and inclines.
  • Some participants state the Capstan Law as T2=T1e^μθ and express confusion about identifying T1 and T2 in different situations.
  • One participant suggests that naming the forces descriptively (Tload and Teffort) may clarify which is which, asserting that it should be obvious in most cases.
  • Another participant questions whether the heavier load is always Tload and the lighter is Teffort, raising concerns about scenarios where weight is not clearly defined or when an incline is involved.
  • A participant proposes that the tight side corresponds to load and the slack side to effort, but acknowledges that labeling could be reversed, leading to uncertainty.
  • Some participants express a desire for a definitive rule to determine which tension corresponds to load and which to effort, but this remains unresolved.
  • There is a discussion about the relevance of energy and movement, with some arguing that energy transfer is not applicable without movement, while others assert that energy considerations are relevant when the capstan is rotating.
  • One participant mentions the concept of Virtual Work as a way to approach the problem when there is no movement.
  • Another participant clarifies that efficiency relates to work input and output, suggesting that the terms load and effort may not be appropriately used in all contexts.
Participants do not reach a consensus on how to identify T1 and T2, with multiple competing views on the definitions of load and effort and their relationship to weight and movement. The discussion remains unresolved regarding the application of these concepts in different scenarios.
Limitations include the ambiguity in defining load and effort based on weight and incline, as well as the lack of clarity on how energy considerations apply in static versus dynamic situations.
physea
Hello!
Capstan law is T2=T1e^μθ.
I have problem identifying T1 and T2 in various situations:
1) when the capstan is not rotating
2) when the capstan is rotating
how can I identify which side is T1 and which T2?
thanks!
Naming the forces descriptively rather than numbers may help:
Tload =Tefforteμθ
It doesn't matter whether the capstan is rotating or not. Identifying which is Tload and which is Teffort should be obvious in most cases.
I still don't understand what is load and what is effort. How can I determine that in a situation like the below?
Is it always the heavier load the Tload and the lighter Teffort? What if it is not given which is heavier and which lighter? Or if a heavier object is at an incline which makes the net force smaller?
Wiki's often helpful:
https://en.wikipedia.org/wiki/Capstan_equation
Well your picture identifies which is the tight and slack which I would expect to correspond to load and effort. Tight being high tension = load, slack being low tension = effort. In other words M > 100kg.
They could just have easily reversed the tight and slack side labelling in which case M < 100kg.
If the tight and slack side were not labelled at all you could find the max M value (>100kg), which corresponds to M being the load, and the minimum M value (<100kg) which corresponds to M being the effort.
The weights will be stationary if M is anywhere between these two limits.
S you are saying that the biggest force is always the Tload and the smaller force is Teffort? If yes, nice, that's what I wanted: a rule to decide which is which.
Yes, that's right.
Work put in times efficiency = Work got out
or
Feffort times distance moved times Efficiency = Fload times distance moved
Efficiency is always less than one.
or
thanks but irrelevant with the topic
I would say that is very relevant because it determines which way the energy is flowing. Isn't that relevant to the thread?
Who asked about energy? There is no energy involved as there is no movement.
The terms Load and Effort refer to a machine. That is defined as an arrangement to do Work - aka transfer Energy. If there is no 'defined' direction for the direction of transfer then you can't say which is the load and which is the effort. That was the message in the OP. When the capstan is rotating there is energy involved.
When there is no movement, you can use the idea of Virtual Work, where an infinitesimal movement is allowed. I remember doing that at A level - but not since.
I am not sure what you did at A levels
Here it is supposed that the effort force is less than the load force, so the efficiency of the capstan is above 1
The ratio of the forces is not the efficiency. Efficiency involves Work in and Work out. (Forces times distances)
In the words of my A level course :
Efficiency is Mechanical Advantage / Velocity Ratio. That will never be greater than unity.
But is the use of the terms Load andEffort helpful or appropriate? If you want to use them then the effort would presumably refer to the force from the load / weight on the end of the rope - the source of energy, if there were any slippage. The load would be the force from your hand - which would be less, due to the friction and so the efficiency would be less than unity (which fits with what we know about efficiency) Using the idea of virtual work (an infinitesimal slippage) - a movement of Δx, the work input would be the work against friction plus the work on the hand.
  • · Replies 32 ·
