Car curves at a radius of 50m while travelling at 100km/hr
  • Thread starter Thread starter MissJewels
    Car Curves Radius
The discussion revolves around calculating centripetal acceleration for various scenarios, including a car on a curve, a jet plane, a stone on a string, a speck of dust on a rotating disk, and a molecule in a centrifugal setup. The subject area includes concepts of circular motion and acceleration in physics.
  • Participants discuss the conversion of velocity to meters per second and the calculation of centripetal acceleration using the formula ar = v²/r. There are questions regarding the need for the coefficient of friction and how to derive angular velocity from revolutions per minute.
Some participants have provided guidance on the calculations needed for centripetal acceleration, while others are exploring specific cases and seeking clarification on their values and methods. There is an ongoing effort to verify calculations and understand the relationships between linear and angular motion.
Participants note the absence of mass values and question assumptions regarding the coefficient of friction. There are also discussions about the correct interpretation of diameter and radius in the context of the problems presented.
MissJewels
Calculate the centripetal acceleration module in the following cases as a multiple of g = 9.8 m / s ^ 2.
a) a car traveling at 100km / h on a curve of radius 50m.
b) a jet plane flying at 1,500 km / h and making a turning radius of 5km.
c) a stone that is rotated every 0.5 s after a string of length 1 m
d) a speck of dust on the edge of a disk of 30 cm diameter rotating at 33.33333 ... rev / min.
e) a molecule in a centrifugal radius of 15cm rotating at 30,000 rev / min.
a)
g= 9.8 m/s2
ar = v2/r
ar = ug
u: coefficient of friction(WHERE DO I GET THIS?!)
haven't touched b) and on yet..
so here's how i began...
converted:
vi = 100km/h = 10 000m/3600s = 27,78m/s
ar= 1002/50 = 200 m/s2
ar = 9,8u
Okay... so how do i get the coefficient of friction(u) if I am not given any mass value?
You don't need the coefficient of Friction for these problems. Convert the velocity to m/s. Square it and divide by the radius in meters to get ac. Divide by 9.8 to get the multiple.
You will need to find the angular velocity for some of these problems and be able to convert from revolutions/min to radians/sec
That's awesome, thanks! I got a, b, and c, but I am stuck on d ... given its diameter, where do i go from there?
Remember that ac=r*ω2 you have r you need to find ω, the angular velocity. The units are radians/sec. The stone makes 1 revolution in .5 seconds. 1 revolution is how many radians? Divide that number by 0.5 sec
I got it, thanks!
I'm doing the d right now...
found that r= 0,015m
w = 0,349 rad/s
and used the equation:
ac=r*ω2
and got ac= 0,0018
then divided it by 9,8... and got 1,84 x10^-4g... when the right answer should just be 1,87g
HELP?
radius is not .015m
ω is not .349 rad/s
Recheck these values and recalculate
  • · Replies 20 ·
