How Does a Car's Oscillation Amplitude Change on a Washboard Road?
  • Thread starter Thread starter Mindscrape
    Car
The discussion focuses on calculating the amplitude of oscillation for a car moving over a washboard road, modeled as an undamped driven harmonic oscillator. The car, with a mass of 1000 kg, experiences a vertical displacement of 1.0 cm for every additional 100 kg of passengers. The amplitude and wavelength of the road's sinusoidal bumps are 5.0 cm and 20 cm, respectively. The final calculated amplitude of oscillation is approximately -1.61 x 10^-4 meters, or 0.161 mm, after correcting the forcing function to account for the spring constant and the amplitude of the bumps.
  • Understanding of Newton's second law
  • Knowledge of harmonic oscillators and their equations
  • Familiarity with differential equations
  • Basic concepts of spring constants and forces
  • Study the derivation of the differential equation for harmonic oscillators
  • Learn about the effects of damping in oscillatory systems
  • Explore the relationship between frequency and amplitude in driven systems
  • Investigate the application of Newton's laws in real-world mechanical systems
Students studying physics, mechanical engineers, and anyone interested in the dynamics of vehicles on uneven surfaces.
Mindscrape
A car with mass 1000 kg, including passengers, settles 1.0 cm closer to the road for ever additional 100 kg of passengers. It is driven with a constant horizontal component of speed 20 km/h over a washboard road with sinusoidal bumps. The amplitude and wavelength of the sine curve are 5.0cm and 20cm, respectively. Find the amplitude of oscillation of the automobile, assuming it moves vertically as an undamped driven harmonic oscillator. Neglect the mass of wheels and springs and assume that the wheels are always in contact with the ground.
Newton's second law
Alright first thing I did was figure out the spring constant.
I know that kx = mg when the car has the 1000 kg, and that k(x-0.01) = (m+100)g. So use equation one and substitute into equation 2, such that k(x-0.01) = kx + 100g. Solve for k and you get that k = 9.8*10^4 Nm.
Next thing is to solve for the frequency of bumps.
I am looking for some function y(t) = cos(\omega t), where there would be some sort of phase that I don't really care about since the amplitude is all that matters in the end. So \omega = 2 \pi f where f is the frequency that the car travels over the bumps. The car travels at 5.5m/s (I converted), and so at 1bump/0.2m multiply it by the velocity and the frequency is 27.7 bumps/sec; hence, \omega = 27.7*2*\pi = 1.74*10^2 rad/s and the forcing function is y(t) = 0.05cos(174t).
At this point, I made the differential equation based on Newton's 2nd law.
\sum_i F_i = m\frac{d^2 y}{dt}
Figure out which forces are in the picture (gravity, spring force, and the forcing frequency).
m \ddot{y} = -mg + ky + 0.05cos(174t)
rewrite in terms of homogeneous and particular ODEs (and divide by m)
\ddot{y} - \omega_0^2y = -g + \frac{0.05cos(174t)}{m} where \omega_0 = \sqrt{k/m}
then we are concerned with just the steady-state (i.e. particular) solution, and guess that it will be y(t) = A + Bsin(174t) + Ccos(174t), which gives
-174^2 Bsin(174t) - 174^2 C cos(174t) + \omega_0^2 A - \omega_0^2 Bsin(174t) - \omega_0^2 Ccos(174t) = 5*10^-5cos(174t) - g
relate the linear and trig terms to show that
A = - \omega_0^2 / g
B = 0
-174^2C - \omega_0^2 C = 5*10^-5
such that
C = \frac{5*10^-5}{(-174^2 + \frac{9.8*10^4}{1000}})
C will give the amplitude of oscillations, but it seems really small (it works out to -1.64*10^-9. I'm pretty sure I did something wrong, but I don't know what.
The units don't come out correctly for your final answer... you should get meters, but you get \frac{meters*sec^{2}}{kg}
Your final answer needs to be multiplied by the spring constant k = 98000 \frac{N}{m} and then you get -1.61x10^-4 meters.
Your problem is with the forcing function: you cannot plug in 5 cm into the forcing function because the forcing function looks like y(t)=Fcos(wt), where F is FORCE.
Therefore, you need to figure out what force, hence name, forcing function, is being applied to the washboard. The force in the forcing function is the spring constant from the suspension system times the amplitude of the washboard sine wave (5 cm, they give you that). Now you got a number in Newtons, hence you get force.
If you re-calculate this, you find out that the final answer is -1.61x10^-4 meters (the units come out very nicely), which is about 0.161 mm
  • · Replies 37 ·
