AlaskanPow
- 13
My problem only gives me joules to work with. Is it possible to convert from joules of energy to temperature (Kelvin)?? If so how?
The discussion centers on calculating the Carnot efficiency of a heat engine, given specific energy transfers. The engine transfers 2.00x103 Joules from a hot reservoir and 1.50x103 Joules to a cold reservoir, resulting in an actual efficiency of 75%. However, to determine the Carnot efficiency, the temperatures of the hot and cold reservoirs are essential. The Carnot efficiency formula is defined as (Thot - Tcold) / Thot, emphasizing the need for temperature data to make this calculation.
PREREQUISITESStudents in thermodynamics, engineers working with heat engines, and anyone interested in understanding the principles of energy transfer and efficiency calculations.
W = Qh-Ql for any heat engine. So this is the definition of efficiency for any heat engine. To calculate the Carnot efficiency, the maximum efficiency of any possible heat engine operating between these two reservoirs, you would need to know the temperatures, Th and Tc.Basic_Physics said:For a Carnot engine it is assumed that all of the extracted heat, QH - QL (high, low), is converted into work by the engine, so that its efficiency is given by
\epsilon=\frac{Q_{H}-Q_{L}}{Q_{H}}
The heat exhausted to the cold reservoir is not the energy output of the heat engine.AlaskanPow said:My book says (efficiency=energy output/energy input)
Which would give me 75% I believe.
So there is no way to get the carnot efficiency?
