AlaskanPow
- 13
- 0
My problem only gives me joules to work with. Is it possible to convert from joules of energy to temperature (Kelvin)?? If so how?
The discussion revolves around the Carnot efficiency of a heat engine, focusing on the relationship between energy transfer and temperature. Participants are exploring how to derive the Carnot efficiency given specific energy values without direct temperature measurements.
The discussion is active, with various interpretations being explored regarding efficiency calculations. Some participants have provided insights into the definitions and assumptions related to Carnot efficiency, while others express uncertainty about the lack of temperature data and its impact on the calculations.
There are constraints regarding the information provided in the original problem, particularly the absence of temperature values necessary for calculating Carnot efficiency. Participants are also navigating the limitations of their textbook's explanations.
W = Qh-Ql for any heat engine. So this is the definition of efficiency for any heat engine. To calculate the Carnot efficiency, the maximum efficiency of any possible heat engine operating between these two reservoirs, you would need to know the temperatures, Th and Tc.Basic_Physics said:For a Carnot engine it is assumed that all of the extracted heat, QH - QL (high, low), is converted into work by the engine, so that its efficiency is given by
\epsilon=\frac{Q_{H}-Q_{L}}{Q_{H}}
The heat exhausted to the cold reservoir is not the energy output of the heat engine.AlaskanPow said:My book says (efficiency=energy output/energy input)
Which would give me 75% I believe.
So there is no way to get the carnot efficiency?
