Carnot Freezer Engine Efficiency Calculation
7 replies · 6K views · last reply
reb659
A Carnot freezer in a kitchen has constant temperature of 260k, while the air in the kitchen has a constant temperature of 300K. Suppose the insulation for the freezer is not perfect and energy is conducted into the freezer at a rate of .15 Watts. Determine the average power required for the freezer's motor to maintain the constant temperature in the freezer.
Qc/Qh=Tc/Th for a Carnot engine
efficiency = (Th - Tc)/(Th)
Work = Qh-Qc
I'm not really sure where to begin. It doesn't seem like I have enough formulas to tackle this problem.
I know power = work/time. So .15J of heat per second are entering the freezer. For a carnot freezer, Work done = Th-Tc = 40J.
Don't confuse T with Q.
If .15J are leaking into the freezer each second, what heat (Qc) needs to be
pumped out per second?
Now use your equations to find work done by the motor per second.
Work = Qh-Qc
Consider the amount of work required to remove a certain amount of heat from the cold reservoir to the hot reservoir. What is the relationship between W, Th and Tc for a Carnot refrigerator?
In this case, .15 Joules/sec have to be moved. The question asks you how much work (per second) you have to do in order to move that amount of heat.
AM
Your missing the Thermal Coefficient. Plug it in and you're there.
Work = Qh-Qc
We've effectively told you Qc.
You are given Tc and Th.
Use your first equation to find Qh,
then your second equation to find work.
This ain't rocket science, although it might be relevant to it:)
