Cart Striking Spring: Velocity & Equations
  • Topic:
  • Thread starter Dustinsfl
    Cart Spring
5 replies · 2K views · last reply
Dustinsfl
A cart starts from a height h and goes through a loop of radius r. After going through the loop the cart stikes a spring with spring constant k. How for is the spring depressed.
I have solved for the velocity at the top of loop, \(v^2 = gr\).
I am stuck with coming up with the equation of motion for the cart strike.
m\ddot{x} = -kx +\text{veloctiy?}
do I have \(\sqrt{gr}\) as well? If not, are there any other forces to consider?
The equation of motion is:
m\ddot{x} = -kx
And no, there are no other forces to consider once the cart is coming out of the loop.
But rather than using the equation of motion, I would use that the energy of a compressed spring is $\frac 1 2 k x^2$, which must be equal to the initial gravitational energy $mgh$.
Btw, note that it is not given that the cart starts from the top of the loop. It is only given that it starts at height $h$.
m\ddot{x} = -kx
And no, there are no other forces to consider.
The height h is a point before the loop. \(h\geq \frac{5}{2}r\) in order to make it through the loop.
So you are saying use the conversation of energy equation.
mgh_i+ 0\cdot KE = mgh_f + \frac{1}{2}kx^2
What would \(mgh_f\) be though?
I assume $h$ is the height above the spring.
Yes. The spring would be h = 0 after the cart goes through the loop.
So is it
mgh = \frac{1}{2}kx^2\Rightarrow x = \sqrt{\frac{2mgh}{k}}
but using the fact that \(h\geq \frac{5}{2}r\), we have
x\geq\sqrt{\frac{5mgr}{k}},
correct?
So is it
correct?
Yes.
That is assuming that the cart stays in contact with the loop while going through it.
It seems that that piece of information is not given.
