Cat on a Plank Torque Problem: How Close Can the Cat Walk Before the Plank Tips?
  • Thread starter Thread starter Andrews989
    Torque
A cat walks on a 4.20-meter plank supported by two sawhorses, with one positioned 0.440 meters from the left end and the other 1.50 meters from the right. The cat weighs 3.3 kg, and the plank has a mass of 5.00 kg. To determine how close the cat can walk to the right end before the plank tips, the torque created by the cat's weight must equal the counteracting torque from the plank's weight. The calculations show that the cat can walk 0.59 meters from the right end before tipping occurs. This solution highlights the importance of considering both the cat's and the plank's weight in torque calculations.
Andrews989
A cat walks along a uniform plank that is 4.20 long and has a mass of 5.00 . The plank is supported by two sawhorses, one 0.440 from the left end of the board and the other 1.50 from its right end.
If the cat has a mass of 3.3 , how close to the right end of the two-by-four can it walk before the board begins to tip?
Net force = 0
Net torque = 0
F=ma
Torque = r * F * sin(theta)
Since the board is just beginning to tip, there is no weight on the left sawhorse.
So the right side the torque is equal to the force (mass * g) times the distance which is the unkown?
Force = 3.3*9.81 = 32.37 N
Torque = 32.37 N * d?
I'm stuck...
So far, so good. You found an expression for the clockwise torque due to the cat's weight. What's providing the counter-clockwise torque?
Mass of the board. Which you count the mass from the center of gravity.
So, the plank is 4.2m. The center is 2.1m. The axis of rotation is 1.5m from the right. Making the plank .6 meters from the axis of rotation (to the left).
The the torque of the plank is .6m times 5kg * 9.81 = 29.3.So the torque on the left has to equal the torque on the right?
29.3 = 32.37 N * d
d = .91 meters?
It's online homework and that is wrong... so something is wrong...
You found the cat's distance from the pivot. How far is that from the end?
Oh. Didn't think about that. So 1.5 - .91 = .59 meters...which is the correct answer. Thanks!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
