Cathode Ray Tube Magnetic Question
2 replies · 6K views · last reply
science.girl
The figure from the link below shows a cross section of a cathode ray tube. An electron in the tube initially moves horizontally in the plane of the cross section at a speed of 2.0 x 107 meters per second. The electron is deflected upward by a magnetic field that has a field strength of 6.0 x 10-4 tesla.
a. What is the direction of the magnetic field?
b. Determine the magnitude of the magnetic force acting on the electron.
c. Determine the radius of curvature of the path followed by the electron while it is in the magnetic field.
An electric field is later established in the same region as the magnetic field such that the electron now passes through the magnetic and electric fields without deflection.
d. Determine the magnitude of the electric field.
e. What is the direction of the electric field?
I found the picture at this link on page 6: harmonphys.info/magnetism%20problems.doc
F = qvBsin[tex]\theta[/tex]
r = (mv)/(qB)
a) It is directed out of the page by the right hand rule. (Did I do this properly?)
b) F = qvBsin[tex]\theta[/tex]
F = (1.60*10^(-19) C)(2.0*10^7 m/s)(6.0*10^(-4))sin[tex]\theta[/tex]
How do I determine [tex]\theta[/tex]?
c) r = (mv)/(qB)
r = [(9.11*10^(-31) kg)(2.0*10^7 m/s)] / [(1.60*10^(-19) C)(6.0*10^(-4) T)
r = .1898 m
d) Would the electrical and magnetic fields cancel? How do I set this up?
e) Would this be the opposite of (a)? [i.e., into the page?]
r = (mv)/(qB)
v and B are perpendicular. Therefore θ is 90 degrees.
c) r = (mv)/(qB)
r = .1898 m
e) Would this be the opposite of (a)? [i.e., into the page?][/QUOTE]
Due to magnetic field B, the centripetal force mv^2/r bends the electron beam in the upward direction. To nullify this deflection an electric force Eq should act in the downward direction.
