Cauchy riemann equations and constant functions
5 replies · 5K views
reb659
Let f(z) be analytic on the set H. Let the modulus of f(z) be constant. Does f need be constant also? Explain.
Hint: Prove If f and f* are both analytic on D, then f is constant.
I think f need be constant.
Let f*=conjugate operator
Let f = U+iV Then f* = U-iV
Since F is analytic we can use CR equations and we get
1) Ux = Vy
and
2) Uy = -Vx .
Applying CR to f* gives
3) Ux = -Vy
and
4) Uy = Vx
1) and 3) imply Vy = -Vy and 2) and 4) imply Vx = -Vx.
But the only function that can equal its negative is zero, and thus Vx = Vy = 0, and so V = constant.
Likewise, the same argument for Ux and Uy gives Ux = Uy = 0 and so U = a constant. And both U and V constant implies that f is constant. So we have the hint proven. Let f = u+iv. We’re given |f| = c.
Stuck.
Hint: f times f* is |f|^2 which is a constant.
But what about the function f(z)=z=x+iy? Isn't that function analytic on the say, unit disk with a constant modulus but f is not constant?
If you mean the unit disk, it doesn't have constant modulus. If you mean the unit circle, yes, it does. They should have stated assumptions on the domain H. Let's say it needs to be open and connected.
Ah yes, I meant unit circle. I was thinking the domain would need to have restrictions because I thought I proved it yet found a counterexample at the same time. But for the original problem:
Let f=U + iV. We have |f|=c for some constant c. |z|^2=zz*, so we have |f|^2=c^2 which implies f*=c^2/f. f is analytic by assumption and constants are always analytic over any D, so by the above hint I proved f must be constant.
Sure, that's it.
