Cauchy-riemann using polar co-ordinates
  • Thread starter Thread starter randybryan
    Polar
randybryan
I've been given a function U(x,y) where f(z) = U(x,y) + iV(x,y)
and asked to check if it is harmonic and then work out what V(x,y) is
U(x,y) = \frac{y}{(1 - x)^{2} + y^{2}}
To check if it is harmonic I can see if d2U/dx2 + d2U/dy2 = 0
I've tried differentiating and it's fairly arduous, so I'm thinking it might be easier to use polar co-ordinates (As a lot of the other questions simplify when doing this). Can anyone think of a suitable substitution to make the differentiation easier?
the answer in the back of the book says that f(z) = -i / (1 - z)
I suggest you consider the logarithm of the function.
log u = log y + log((1-x)2+y2)
\frac{1}{u}\frac{\partial u}{\partial y}=\frac{1}{y}+\frac{2y}{(1-x)^2+y^2}
\frac{\partial u}{\partial y}=\frac{1}{(1-x)^2+y^2}+2u^2
Thanks, but I still don't know where to go from here
So its not helping after all.
I give a try for the second derivatives and obtain
u_{yy}=\frac{2u^2}{y}+8u^3 and u_{xx}=\frac{-2u^2}{y}+\frac{8(1-x)^2u^3}{y^2}
so that
u_{xx}+u_{yy}=\frac{8u^2}{y}\neq 0 ?
TRY this
for a function to be harmonic its laplacian should be zero
so \nabla2U = 0
( i worked it out and it is true)
THEN use the Cauchy Rienman conditions to determine v
Finally the f(z)=U+iV
  • · Replies 27 ·
  • · Replies 27 ·
  • · Replies 19 ·
  • · Replies 16 ·
