Center of mass acceleration for an inclined plane and mass m
The discussion revolves around the acceleration of the center of mass for a system consisting of a mass on an inclined plane. Participants are exploring the dynamics of the system, particularly focusing on the forces acting on the mass and the inclined plane.
  • Participants question the conditions under which the center of mass acceleration is considered zero, discussing the implications of external forces acting in different directions.
  • There are inquiries about calculating the center of mass acceleration in the vertical direction and the normal force acting on the mass.
  • Some participants suggest using conservation laws and relative motion to analyze the problem, while others mention the complexity of the interactions between the two bodies.
The conversation is ongoing, with participants providing insights and raising questions about the nature of the forces involved. Some guidance has been offered regarding the use of relative motion and conservation principles, but no consensus has been reached on the specific calculations or methods to apply.
Participants note that the problem is set in a high school physics context, focusing on two-body systems and the dynamics of center of mass. There is mention of the challenge in analyzing the forces due to the non-inertial frame of reference created by the inclined plane.
Sam Jelly
Mass m is on top of an inclined plane of mass M, let mass m slide down. (All surfaces are frictionless) I’m trying to find the center of mass’s acceleration.
(m+M)Acm=Fexternal
Why is the center of mass acceleration zero? Did I do anything wrong?
There is no net external force on the system in the horizontal direction. Although I don't think you properly analyzed it, because in the vertical direction the center of mass is accelerating.
All the external forces are in the vertical direction but it all cancels out.
The vertical coordinate of the combined center of mass ( block and ramp) is accelerating as the small block accelerates down the ramp. What you did is not correct.
How can I calculate Acm in the y axis? I know that the center of mass is accelerating down in the vertical axis but I don’t know how to calculate the external forces acting on it.
This is a tricky problem because both blocks accelerate. Where did you get this problem?
Have you studied Lagrangian mechanics?
I believe applying Conservation of Momentum, Energy are the most straightforward, other methods include examining Newtons Laws in a non-inertial frame for each mass, or the mathematical machinery of the Lagrangian (if you've studied it as @PeroK mentions).
I'll yield any further assistance to those that know each of these methods by heart (I'd have to go through it myself first - if @PeroK says it's tricky - I'm probably underestimating it), as I'm currently cooking Easter dinner!
It’s a problem from my high school class. We are studying about 2 body systems like reduced mass and center of mass etc. I am confused why all external forces in the vertical axis all cancel out.
They don't cancel out the way you think they do or imply they do in your calculations. Imagine a block on a scale. The scale reads ##mg##, now take that block and scale lift it up and drop it, what does the scale read while it's in freefall?
It’s zero. So does that mean my Normal force here is incorrect?
Yes, the normal force on the base of the wedge is incorrect. That little block has some aceleration in the vertical direction between ##0 ~[m/s^2]## and ##g##(freefall) in magnitude.
I see, is there any way to calculate the normal force?
There are probably a handful, but none are simple, (how far along you are in you your physics)? Calculus, Momentum, Energy, Newtons Laws in non-inertial frames? I think finding the normal force is one of the more involved you'll find tied to this problem. The experts around here would be better at suggesting steppingstone problem that is at your level of experience than me trying to make one up for you. I think one might be to instead ask you to find what is the velocity of the wedge as a function of the velocity of the block with respect to the slope. Can you think of what principle you might apply to solve that one instead?
I am familiar with calculus. The actual problem is to find the d(v relative)/dt and the center of mass acceleration. Right now I am trying to solve this problem using the 2 body system.
While you wait for someone to help you with that (I've had a long day - I'm not in the frame of mind to start that tonight). Can you solve the problem I asked (as a test of will ) what is the velocity of the wedge ##u## as a function of the velocity of the block relative to the slope ##\dot s ##?
Also, if someone is going to help you through this problem it is critical that you learn to use the math formatting language LaTeX Guide It's what we use here to present out mathematics in a clean and organized fashion.
Not directly. The problem is that downward acceleration of the mass centre is limited by the horizontal inertia. You cannot solve for the two directions independently.
You could look at the kinematic relationship between the vertical and horizontal positions of the small mass (since the horizontal relationship of the two objects is known) and/or consider work conservation.
A sure way, but maybe longer, is to consider the normal force between the objects and apply F=ma to each separately.
Sam Jelly said:
Homework Statement: Mass m is on top of an inclined plane of mass M, let mass m slide down. (All surfaces are frictionless) I’m trying to find the center of mass’s acceleration.
Relevant Equations: (m+M)Acm=Fexternal
The first thing to note is that the small mass has some velocity ##\vec v## relative to the ground; and, it has some velocity ##\vec v'## relative to the block. And, the block has some velocity ##\vec V## relative to the ground.
Imagine what happens in a small time interval ##\Delta t##:
1) The block will have moved ##\vec X = \vec V\Delta t## to the left.
2) The small mass will have moved ##\vec s' = \vec v'\Delta t## down the block.
3) The displacement of the small mass relative to the ground is the vector sum of these two displacements:$$\vec s = \vec X + \vec s'$$4) And, the displacement of the small mass can be expressed in terms of its velocity relative to the ground:$$\vec s = \vec v \Delta t$$Note that by differentating these equations we can see that the acceleration of the mass is the vector sum of the acceleration of the block and the acceleration of the mass relative to the block:$$\vec v = \vec V + \vec v'$$$$\vec a = \vec A + \vec a'$$Any solution will have to deal with the relative motion of the objects. So, I think these equations are your starting point.
I had a look at this and found a relatively elementary way to do things. Note that in the ground frame:
1) The horizontal displacement of the mass and the block are related.
2) The vertical displacement of the mass is related to the horiziontal displacement. To calculate this, draw a diagram of the starting position and another diagram when the mass has moved some distance down the slope.
3) Express the KE of the system in terms of the vertical displacement of the mass.
4) The PE lost by the system can, of course, be described by the vertical displacement of the mass.
5) Combine and solve those equations to get the vertical acceleration of the mass.
6) Calculate the acceleration of the CoM from that.
  • · Replies 25 ·
  • · Replies 17 ·
