Center of Mass and Motion of Objects: A Mechanics Exam Review Question
The discussion revolves around a mechanics problem involving a boat and a child, focusing on the concept of center of mass and motion. The child walking to the far end of the boat will cause the boat to slide in the opposite direction, maintaining the overall center of mass of the system. The initial positions of both the boat and child are stationary, leading to the conclusion that as the child moves, the boat also moves to keep the center of mass in place. The key takeaway is that the boat will not remain stationary; both the child and the boat will move to preserve the center of mass. Understanding this principle is crucial for solving the problem correctly.
jstep
I'm doing a review for a Mechanics exam I have tomorrow and this first problem given on the review struck me as odd.
Problem Statement:
An 89kg boat that is 6.6m in length is initially 7.1 m from the pier. A 27 kg child stands at the end of the boat closest to the pier. The child then notices a turtle on a rock at the far end of the boat and proceeds to walk to the far end of the boat to observe the turtle.
How far is the child from the pier when she reaches the far end of the boat? Assume there is no friction between boat and water.
Answer in units of m.
I tempted to just say 13.7m; but I'm guessing that somehow the child walking across the boat will cause it to slide across the water in the opposite direction. Is this somehow a momentum problem? But I have no way of knowing how quickly the child moves...
The other chain of thought i followed would cause the child's position to stay the same, while the boat moved. But I'm not sure how the different masses would play into this situation and surely it can't be that simple...
What am I missing here?
Thanks!
Conservation of momentum always applies, even without knowing the actual velocities involved. It leads to another useful property of isolated systems: Newton's first law applies to the center of mass of the system.
So, given that the boat and child are initially stationary, their center of mass is likewise stationary.
so the child's position would remain constant as the position of the boat changes?
No, the isolated system in this case comprises both the child and the boat.
so then the boat will remain stationary as the child walks across it?
vi, child = 0
vi, boat = 0
mboatvi, boat + mchildvi, child = 0
vf, child > 0
vf, boat = ?
mboatvi, boat + mchildvi, child = mboatvf, boat + mchildvf, child
0 = 89vf, boat + 29vf, child
if vf, child > 0
vf, boat must be 0.
is this correct?
No. The boat and child must both move in such a way as to hold the center of mass stationary.
You won't have to consider the velocities at all, merely the location of the center of mass.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
