Central force on a particle following a logarithmic spiral
25 replies · 4K views
JD_PM
Given a central force field that allows to keep particles in the following logarithmic spiral ##r( \theta ) = k e^{\alpha \theta}## (where ##k## and ##\alpha## are constant).
a) Determine ##r(t)## and ##\theta (t)##.
b) Give the equation of the force.
c) Discuss the nature of the force fields associated to the obtained force.
$$m( \ddot r - r \dot \theta^2 ) = F(r)$$
$$m( r \ddot \theta + 2 \dot r \dot \theta) = 0$$
I want to focus this question on understanding the force ##F(r)## I get (thus, I want to focus on c) ). However, below the dashed line, I included steps on how I derived ##F(r)##.
We are going to work in polar coordinates.
Knowing that the acceleration is:
$$a = \Big( \ddot r - r \dot \theta^2 \Big) \hat r + \Big( r \ddot \theta + 2 \dot r \dot \theta \Big) \hat \theta$$
Newton's second law ends up with the form:
$$F(r) = m \Big( \ddot r - r \dot \theta^2 \Big) \ \ \ \ (1)$$
$$m \Big( r \ddot \theta + 2 \dot r \dot \theta \Big) = 0 \ \ \ \ \ \ \ (2)$$
a)
$$\theta (t) = \frac{(At + B)}{mr^2} \ \ \ \ \ (3)$$
$$r (t) = k \ exp \Big(\alpha \frac{(At + B)}{mr^2} \Big) \ \ \ \ \ (4)$$
b)
$$F(r) = m \Big[ k\Big( \frac{A \alpha}{m r^2} \Big)^2 e^{\frac{B \alpha}{m r^2}} e^{\frac{A \alpha t}{m r^2}} - \frac{1}{r^3} \Big(\frac{A}{m}\Big)^2 \Big] \ \ \ \ \ (5)$$
c)
Let me define the following quantities to simplify the equation for ##F(r)##
$$C = \frac{A}{m}$$
$$D = \frac{B}{m}$$
So we get a central force of the form:
$$F(r) = m \Big[ k\Big( \frac{C \alpha}{ r^2} \Big)^2 e^{\frac{D \alpha}{r^2}} e^{\frac{C \alpha t}{ r^2}} - \frac{C^2}{r^3}\Big] \ \ \ \ \ (6)$$
Alright so one notices that the repulsive inverse square field and the attractive inverse cube field are involved.
However, what can we say about the exponents?
Thanks.
a)
- Getting ##\theta (t)##
OK so ##(2)## can be rewritten as follows:
$$\frac{d}{r dt} \Big( m r^2 \dot \theta \Big) = 0$$
Integrating twice with respect to ##t## we get:
Where ##A## and ##B## are constants.
- Getting ##r (t)##
By plugging in equation ##(3)## into the given equation ##r( \theta ) = k e^{\alpha \theta}## we get ##r (t)##
b)
So we just have to use equation ##(1)## to get:
on Phys.org
JD_PM said:
$$m( r \ddot \theta + 2 \dot r \dot \theta) = 0$$ ...
(2) can be rewritten as follows ...
Integrating ##{\displaystyle {d\over dt}}\Bigl ( mr^2\dot \theta \Bigr) = 0\ ## once with respect to ##t## we get
##\Bigl ( mr^2\dot \theta \Bigr) = A\ ##, i.e. angular momentum is constant.
How do you get (3) from that ?
Can you elaborate more on your question? Do you want a graph of function?
BvU is pointing out that you made a mistake in going from
$$\frac{d}{ dt} \Big( m r^2 \dot \theta \Big) = 0$$
to
You said that you integrated the first equation twice with respect to time. But it appears that you treated ##r## as a constant in the second integration.
TSny said:
BvU is pointing out that you made a mistake ... you treated ##r## as a constant in the second integration.
You both are right, let's fix it.
Let me use:
$$C = \frac{A}{m}$$
The idea is to integrate the following equation with respect to time (where both ##r## and ##\theta## are functions of time):
$$\int d \theta= \int \frac{C}{r^2} dt \ \ \ \ (7)$$
We do not know what is the explicit formula for ##r(t)## but we know what's it for ##r(\theta )##
$$r( \theta ) = k e^{\alpha \theta}$$
My idea is to use the chain rule to get ##r(t)##:
$$\frac{d}{dt} r(t) = \frac{dr}{d \theta}\frac{d \theta}{dt} = k \alpha e^{\alpha \theta} \dot \theta \ \ \ \ (8)$$
The next step is plugging ##(8)## into ##(7)## and integrate.
Multiplying top and bottom of the RHS of ##(7)## by ##(\frac{d}{dt})^2##, I get:
$$\frac{(\frac{d}{dt})^2 C dt}{(\frac{d}{dt} r)^2} = \frac{(\frac{d}{dt})^2 C dt}{ (k \alpha e^{\alpha \theta} \dot \theta)^2} = \frac{ C dt}{ (k \alpha e^{\alpha \theta} d\theta)^2} $$
Which leads to:
$$\int k \alpha e^{\alpha \theta} (d \theta)^3 = \int C dt$$
I've done something wrong because ##d \theta## shouldn't be to the power of three.
Do you agree on the idea of using the chain rule though?
Another idea is to use or derive the general central force equation:
$$\frac{d^2}{d\theta^2}(\frac 1 r ) + \frac 1 r = -\frac{mr^2}{l^2}F(r)$$
OK. Note that this may be written as $$\dot r = \alpha r \dot \theta \ \ \ \ (8')$$
What you did here is a wild ride! :oldsmile:
But it's not correct. You cannot treat ##(\frac{d}{dt})^2## this way.
In your first post, you arrived at ##\frac{d}{rdt} (mr^2\dot\theta) = 0## which may be simplified to ##\frac{d}{dt}(r^2 \dot \theta)=0##.
So ##r^2 \dot \theta = C##, where ##C## is a constant. (##C## is the angular momentum per unit mass.) Solve this for ##\dot \theta## and substitute into equation (8') above.
If you've got this far, perhaps solving for ##r## first is simplest!
I have the impression that mathematicians treat ##\frac{d}{dt}## differently than physicists, don't they?
TSny said:
Try solving this for ##\dot \theta## and then substitute into equation (8') above.
We have:
$$\dot \theta = \frac{C}{r^2} \ \ \ \ (9)$$
Plugging ##(9)## into ##(8')## we get:
$$\dot r - \frac{\alpha C}{r} = 0$$
This is a linear first order homogeneous ODE whose solution is (if you do not agree I'll include the steps):
$$r(t) = \pm \sqrt{2C(\alpha t + E)} \ \ \ \ (10)$$
Where ##E## is the constant of integration.
Plugging ##(10)## into ##(9)## we get:
$$d \theta = \frac{d t}{2C(\alpha t + E)}$$
This is a first order homogeneous ODE whose solution is (if you do not agree I'll include the steps):
$$\theta (t) = \frac{ln(\alpha t + E)}{2 \alpha} + F$$
Where ##F## is the constant of integration.
The double derivative of ##(10)## with respect to time is:
$$\ddot r = \frac{-2 \alpha^2 C^2}{4(2C(\alpha t + E))^2} = \frac{-\alpha^2 C^2}{2r^2}$$
The force ##F(r)## I get is:
$$F(r) = m \Big( \frac{-\alpha^2 C^2}{2r^2} - \frac{C}{r}\Big)$$
There may be something wrong. Checking dimensional analysis ...
EDIT: As PeroK pointed out, this result is not OK. Dimensional analysis of ##\frac{-\alpha^2 C^2}{2r^2}## yields ##L^2##, while it should yield the dimension for acceleration: ##\frac{L}{T^2}##
First, you should be able to simplify this immediately to:
$$r(t) = \sqrt{r_0^2 + 2C\alpha t}$$
Second, you already have an equation relating ##r## and ##\theta##, so use that instead of integrating ##\theta##.
To get ##f(r)## you can again shortcut things by using the constant angular momentum to avoid differentiating ##\theta##.
PS I'd replace ##C = l/m## where ##l## is the angular momentum.
This can't be correct.
By this I mean that, using ##l = mr^2 \dot \theta##, we have:
$$f(r) = m(\ddot r - r \dot \theta^2) = m(\ddot r - \frac{l^2}{m^2 r^3})$$
Which one?
The only equation I see is ##\dot r = \alpha r \dot \theta##, and we need to integrate it.
JD_PM said:
Which one?
You forgot this one!
JD_PM said:
Homework Statement:: Given a central force field that allows to keep particles in the following logarithmic spiral ##r( \theta ) = k e^{\alpha \theta}## (where ##k## and ##\alpha## are constant).
OK I made a mistake here:
It is
$$\ddot r = \frac{-\alpha^2 C^2}{r^{3/2}}$$
Thus the force is:
$$F(r) = m \Big( \frac{-\alpha^2 C^2}{r^{3/2}} - \frac{C}{r}\Big)$$
But this is again wrong (I checked dimensions and do not match).
I do not see why, as I checked several times my computations and they are OK.
EDIT: I am going to try the procedure PeroK suggested
It is
Thus the force is:
Sadly, I think both terms are wrong. If ##r = (a + bt)^{1/2}##, then time derivatives of ##r## involve (odd) integer powers of ##r##.
Alternatively, try implicitly differentiating ##r^2##.
I don't see how you got the second term. See post #12.
PS If you get ##F(r)## using post #6, you can see what you're aiming for!
Alright, so from post #12 we see that ##F(r)## is:
$$F(r) = m \Big( \ddot r - \frac{C^2}{r^3}\Big)$$
By differentiating equation (10) we get:
Thus:
$$F(r) = m \Big( \frac{-\alpha^2 C^2}{r^{3/2}} - \frac{C^2}{r^3}\Big)$$
Which can be rewritten as:
$$F(r) = \frac{A^2}{mr^2} \Big( \frac{-\alpha^2 }{r^{-1/2}} - \frac{1}{r}\Big)$$
I am closer to the equation you gave at #6;
I am sure there has to be a way to go from ##\frac{-\alpha^2 }{r^{-1/2}}## to ##\frac{d^2}{d\theta^2}(-\frac 1 r )##... but how? I have been trying to use the chain rule. We also know ##r(\theta)## from the exercise statement. I suspect we could also use it to get rid of ##\alpha##
OK
The power of ##r## in the denominator is not correct. Once you fix that, you will see that ##F(r)## has a nice dependence on ##r##.
Oops my bad. Now fixed:
$$\ddot r = \frac{-\alpha^2 C^2}{r^3}$$
Thus ##F(r)## is:
$$F(r) = \frac{A^2}{mr^2} \Big( \frac{-\alpha^2 }{r} - \frac{1}{r}\Big)$$
This expression is OK. I've noticed that the expression ##\frac{-\alpha^2 }{r}## is OK, as ##\alpha## is dimensionless.
To put it in the same form PeroK suggested in #6, we see that:
$$\frac{d^2}{d \theta^2} \Big(\frac{1}{r}\Big) = \frac{\alpha^2 }{ke^{\alpha \theta}}$$
Thus:
$$F(r) = \frac{A^2}{mr^2} \Big( -\frac{d^2}{d \theta^2} \Big(\frac{1}{r}\Big) - \frac{1}{r}\Big)$$
Thank you all, it was fun!
Nature of the obtained force
Only the attractive inverse cube field is involved.
$$\frac{d^2}{d \theta^2} \Big(\frac{1}{r}\Big) = \frac{-\alpha^2 }{ke^{\alpha \theta}}$$
Just an observation. It looks odd to me that you leave expressions in the form that you do. Maybe it's just style, but I would have written:
$$F(r) = \frac{A^2}{mr^2} \Big( \frac{-\alpha^2 }{r} - \frac{1}{r}\Big) = -\frac{A^2}{mr^3}(\alpha^2 +1)$$
$$\frac{d^2}{d \theta^2} \Big(\frac{1}{r}\Big) = \frac{-\alpha^2 }{ke^{\alpha \theta}} = -\frac{\alpha^2 }{r}$$
$$F(r) = \frac{A^2}{mr^2} \Big( -\frac{d^2}{d \theta^2} \Big(\frac{1}{r}\Big) - \frac{1}{r}\Big) = -\frac{A^2}{mr^3}(\alpha^2 +1)$$
It's almost like you switch off one step before the end. It's a minor point, perhaps.
I think the issue is a bit overcomplicated in this thread. The point is that you have given the trajectory in terms of ##r=r(\theta)##. You don't care about how the trajectory is run through as a function of time. The two "homework equations" are all you really need.
The 2nd equation is nothing else than angular-momentum conservation, i.e., you can integrate it to
$$r^2 \dot{\theta}=\ell=\text{const}. \quad (*)$$
Then you introduce the central potential
$$V(r)=-\int \mathrm{d} r F(r)$$
and use the energy-conservation law,
$$\frac{m}{2} \dot{\vec{x}}^2 + V(r)=E=\text{const},$$
which reads in polar coordinates
$$\frac{m}{2} (\dot{r}^2 + r^2 \dot{\theta}^2)+V(r)=E. \qquad (**)$$
Now you can eliminate ##\dot{\theta}##, using (*) and get a differential equation for ##\mathrm{d}r/\mathrm{d} \theta=\dot{r}/\dot{\theta}## from (**), which let's you derive ##V(r)## from the given solution ##r=r(\theta)##.
Thank you for your post vanhees71! :)
But note that ##a)## is asking for ##r(t)## and ##\theta (t)##.
Part a) in the OP asked for the trajectory as a function of time!
vanhees71 said:
Yes, and this you get after you've found ##V(r)## by solving the equation of motion for ##r##.
The direct approach could have been done more efficiently:
$$r = ke^{\alpha \theta}$$
$$\dot r = \alpha r \dot \theta = \frac{\alpha l}{mr}$$
$$\frac{d(r^2)}{dt} = 2r \dot r = \frac{2\alpha l}{m}$$
$$r = (r_0^2 + \frac{2\alpha l}{m}t)^{1/2}$$
