What is the difference between centrifugal and centripetal forces?
  • Thread starter Thread starter kthayes
    Centrifugal
Centrifugal force acts outward from the center in a rotating system, while centripetal force acts inward, keeping objects in circular motion. Centrifugal force is considered a fictitious force, as it only exists in a rotating frame of reference and requires an external constraint to be felt. In contrast, centripetal force is a real force that opposes centrifugal force and is necessary for maintaining circular motion. For example, in a washing machine, centripetal force keeps clothes moving in a circle while centrifugal force pushes water outward. Understanding these forces is crucial for analyzing motion in rotating systems.
kthayes
Maybe misspelled, i know. What is the difference between the two?? Please explain.
Centripetal - towards the center
Centrifugal - away from the center
Centrifugal force is exerted from clothes, towards the drum, in a spin cycle. It works away from center, when the water and clothes are pressed towards an outer constraint. Fugal is latin for escaping, and the former conseption was to think that a force was pushing the object away from center. Centrifugal force is, however, not a force until the object presses on to something. Until then it is an imaginary force.
Centripetal force is the force opposing centrifugal force, inwards. Petere means "tend towards". The spin cycle drum would be exerting centripetal force on the clothes. The water escapes through the holes, so allthough some centripetal/centrifugal force is given to water as well (or else the clothes would dry instantly/completely), the lack of centripetal- and the equal sentrifugal force is what allows water to escape. Escaping water continues straight forward (like a car not turning), while clothes keep on turning.
Hope this helps, somehow.:smile:
so, basically the "third law" thing, right? if i have centrifugal motion, equal and op. is centripital?
Yes, but 1st, as much
Thanx Vespa...'71...nice lookin vespa
Centrifugal force only exists in a rotating frame of reference. This is the force that flings matter outward from the rotation center. It's called a fictitious force because it only exists due to a certain choice of coordinates. Note, there's no "equal and opposite force" to the centrifugal force. The force is coming out of space itself. An object being flung out from the center can't "feel" the centrifugal force unless there's something in the way. If it is stuck against a wall, the force it actually feels pushing against the wall is centripetal force.
Centripetal force is a regular force in that it must occur with a matching opposite force. This force exists no matter if you are in a rotating or non-rotating frame. For example, a rock attached to a string that is swinging around--the string pulls on the rock inward, and the rock pulls on the string outward. This is a real force and an actual interaction between two pieces of material.
  • · Replies 22 ·
  • · Replies 93 ·
  • · Replies 16 ·
  • · Replies 43 ·
