Centripetal acceleration of a hammer whirled at 1.76 rev/s
6 replies · 3K views
TwoTeez
1. An athlete whirls a 7.48 kg hammer tied to
the end of a 1.4 m chain in a horizontal circle.
The hammer moves at the rate of 1.76 rev/s.
What is the centripetal acceleration of the
hammer? Assume his arm length is included
in the length given for the chain.
Answer in units of m/s
2. Equations I am pretty sure I need are
v = 2∏r/T
and
ac= v2/r
not sure if I need any others.
3. I tried finding v first, and I assumed the 1.76 rev/s was T, so I did 2*∏*1.4(about 8.80) and divided it by 1.76, getting about 4.99 m/s
and I plugged it into the ac equation.
So I squared the 4.99, getting about 24.98, and dividng it by 1.4, which gets me about 17.843.
But that answer is wrong.
I don't know what the answer is.
I feel like what I am doing wrong is the 1.76 rev/s is not T, or it is, but I have to change it so it's in like m/s or something like that. If that's the case, then I need help finding that because I have no idea how to do that.
Thank you for any help!
in your equation for v, T is the time to complete one revolution (make sure you see why)
1.76 rev/s
is that what you want? or is it seconds per rev?
I think I see where you are getting at.
For every second that passes, it makes 1.76 revolutions.
But to find the velocity, I need to put T as a time per revolution. So would I just do the inverse of T?
So if i do the inverse for T, wouldn't that just be multiplying T with the 2∏r?
But wouldn't I need to the the inverse of everything else as well? What you do to one side of the equation, you do to the other.
So 1/v = T/2∏r
And then do the inverse again to get the answer. But isn't that the same is the answer I would have gotten before? Am I even going in the right direction?
well 1.76 is not T. Your messing around with thinking that it is. 1.76 is the angular speed, completely different from T.
the equation v = 2∏r/T is correct. Find T.
If I want to turn the rev/s into common terms, would I multiply 1,76 by 2∏r?
I have yet to learn about angular speed in my class, so I know practically nothing on it.
So 1/v = T/2∏r
With what you have now, you have 1.76 revolutions over one second. Just do the inverse of that: (1/1.76) to find your period, T
This is the relationship between frequency and period.
You are given a frequency of 1.76 rev/sec.
Frequency is (1/T) T is the period
