Centripetal acceleration problem
The discussion revolves around a centripetal acceleration problem related to a hydroelectric power station's turbine. The turbine has a diameter of 7.5 meters and a rotation frequency of 94 rotations per minute. Participants are attempting to calculate the acceleration of the turbine's blades using various formulas and approaches.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss converting rotational frequency from rotations per minute to rotations per second for calculations. There are questions about which part of the blade the acceleration refers to, with some specifying the tip. Different formulas and methods for calculating acceleration are presented, including discussions about the period of rotation and the relationship between frequency and period.
There is ongoing exploration of the calculations, with some participants questioning the correctness of the provided answer. Multiple interpretations of the formulas and their applications are being discussed, and some participants express uncertainty about their calculations. Guidance is offered regarding the relationship between frequency and period, but no consensus has been reached on the correct approach or answer.
Participants are navigating potential translation issues from another language, which may affect the clarity of the problem statement. There is also mention of discrepancies between calculated results and a provided "correct" answer, leading to further questioning of the assumptions and methods used.
Juliusz
Hydroelectric power station's turbine has a diameter of 7.5m, and a rotation frequency of 94 rotations per minute. What is the turbine's blades acceleration?
P.S. This is translated from another language
a=4π2Rn2
Where n=rotational frequency
My understanding is that I need to convert rotations per minute, to rotations per second for the formula to work. Therefore: 94/60
Though when I plug that in the formula for n, I get a wrong answer.
I also divided the diameter by two to get the radius(R)
4*π2*3.75*(94/60)2≈363.37
The correct answer is 231.7m/s2
Which part of the blade? The tip? The middle? The mass centre? The radius of gyration?
The tip. That's the problem with translating problems from a different language.
Maybe you need to check that calculation.
PS That said, it looks to me like you are correct. I can't see where they get the other answer from.
The ratio between your answer and the "correct" answer is 94/60 (to within 0.1%). It is possible that the supposedly correct answer is not, in fact, correct and that the answer key did not properly square the rotational frequency (as you have it) or the inverse time per rotation (as I usually remember the formula).
This is not the first time that a "correct" answer is actually wrong. Thank god for forums like these, otherwise I would break my head thinking about what I did wrong.
Is this the formula you are referring to?
I solved this problem another way.
I used the two equations:
v= 2(pi)r/T
a=v^2/r
where:
r = radius
T= period
v= velocity
a= circular acceleration
I first found v:
2pi(3.75)/(60/94)
v=36.9m/s
a= 36.9^2 / 3.75 = 363.4m/s^2
Timothy Proudkii said:
I solved this problem another way. However, I think I did something terribly wrong because I am no where near what you got.
v= 2(pi)r/T
a=v^2/r
where:
r = radius
T= period
v= velocity
I first found v:
2pi(3.75)/(94/60)
v=15.04m/s
a= 15.04^2 / 3.75 = 60.32m/s^2
What the period, ##T##, if it's 94 revs per minute?
Since there is 94 revolutions per 60 seconds, then there are 1.57 revolutions per second (94/60) Right? Or do I not understand something?
So, what's the period? Which is the time for a revolution.
One second
One second
Is that your answer? Why would it be ##1s##?
"In mathematics, a periodic function is a function that repeats its values in regular intervals or periods" The blade does a full rotation in 1.57s, I misunderstood your initial question.
And, if it did ##1,000## revs per minute, what would be the period?
16.16 revs per one second.
That's not a period. That's a frequency. The period is the length of time it takes for a revolution.
That ties in with how you tried to calculate your velocity, which was ##2\pi r/T##, where ##r## is the radius of the motion.
AHhhhhH I see, so the period would be 0.06s for 1000 revs per minute?
Yes, in general, period = 1/frequency.
Yes thank you!
$$\frac{\pi^2R}{T^2}=4$$
[rewrote attached formula using LaTeX]
No, that's not what I had in mind. The formula that I learned many years ago was$$a=\frac{4\pi^2r}{t^2}$$
Which is the same as $$a=4\pi^2rn^2$$The only difference is that one uses complete rotations per unit time (n) and the other uses time per complete rotation (t).
I don't know what formula you quoted, but the one attached in my image is the same as you just wrote
Take a look at the thumbnail presentation of the attached image from your post #7.
The attachment is fine. The thumbnail is not.
  • · Replies 28 ·
  • · Replies 20 ·
