Centripetal force of a block on a string
4 replies · 7K views · last reply
physics10
I am really in a jam, I have no idea if I solved this correctly or not, it is due Monday morning 8:00am /eastern time.
Here is the question:
A block is hung by a string from the inside roof of a van. When the van goes straight ahead at a speed of 28m/s, the block hangs vertically down. But when the van maintains the same speed around an unbanked curve (radius=150m), the block swings toward the outside of the curve. Then the string makes an theta with the vertical. Find theta.
This is what I got, I don't know if I am doing it correctly or not.
The sum of Fy=0
ncos theta=mg
theta=tan^-1 (28m/s)^2/(150m)*(9.80m/s)= theta=28 degrees
Please help if you can, you can e-mail me if you like at jc_ro2003@yahoo.com
I don't know how you derived it, but your expression,
[tex]\tan\theta = \frac{v^2}{rg}[/tex]
is correct, and so is the 28 degrees.
The Centripetal force on the van is the 'force' that is causing the ball to swing outwards. By solving the centripetal force of the van, u will be able to get the magnitude of the 'force' that is acting on the ball. By combining with the vertical unchanging force on the ball, gravity (9.81m/s^2), and using tan, u shld be able to the solve.. But i guess u noe that.. Haha:)
thanks
thank you guys for all your help, I am a new member to this site and you guys have been great.
