Centripetal Force on Pendulum: My View
  • Thread starter Thread starter Werg22
    Forces Pendulum
7 replies · 4K views
Werg22
Is there a centripetal force with a pendulum? My view is that mg acts on the mass (for angles lower than 90) with two components. One that is parrallel to the string and another that is perpendicualr to it. Since the center of the pendulum mechanism stays still, by action reaction this component is canceled out on the mass. For a time that goes to zero the mass moves in the direction that was perpendicular to the string. But since the string moves along with the mass, the direction of the mass (which is perpendicular to the string) changes constantly and the result is a circular motion. Is this perception correct or not?
Yes, there's a net centripetal force on the mass, as there must be since the mass moves in a circle around the pivot. The force is NOT constant, though, since the speed of the pendulum varies during the swing. The centripetal force at any time is the vector sum of the weight force and the string tension force.
While there's certainly a centripetal force on the mass, it's not the net force. (It's the net force in the radial direction.) The acceleration of the mass--and thus the force on the mass--has both tangential and radial components.
And this force would be the weight?
Two forces act on the mass in a pendulum: the weight and the tension in the string. The vector sum of these forces is the net force on the mass.
Okay. And this tension is due to the fact that the center of the pendulum stays still, right?
It's due to the fact that one end of the string is fixed while the other end is attached to the swinging mass.
