Centripetal vs Radial acceleration
Centripetal acceleration (a_c) and radial acceleration (a_r) are related but differ in sign due to their directional conventions. Centripetal acceleration is always directed toward the center of a circular path, making it positive, while radial acceleration can be positive or negative depending on the direction of the acceleration vector relative to the origin. The negative sign in the equation a_r = -a_c indicates that radial acceleration points away from the center when considering the radial unit vector. This distinction is crucial in understanding motion in curved paths and the behavior of forces, such as in the case of repelling charges. The discussion emphasizes that the difference is primarily a matter of sign convention rather than a fundamental difference in acceleration types.
Amio
I am reading introductory physics from Serway. Where they say if a_r is radial acceleration and a_c is centripetal acceleration then a_c = v^2/r and a_r = -a_c = - v^2/r
But aren't the radial and centripetal acceleration same (correct me if I am wrong)? Why is there a minus sign?
The book explains by saying that the negative sign indicates that the direction of centripetal acceleration is towards the center of the circle representing the radius of curvature..
I don't understand this explanation because as the direction of the radial acceleration is also towards the center, shouldn't it be a_{radial} = a_{centripetal} ? Why the minus sign?
Would someone please clarify?
Do you know what spherical coordinates are? The radial component of a vector is the projection of that vector onto the radial unit vector. That vector points away from the origin. Thus the radial component of acceleration is positive if the acceleration vector is pointing away from the origin.
Centripetal acceleration is acceleration toward the center.
It's just a sign convention, nothing else.
Likes 1 person
Thank you.
The term centripetal acceleration applies only when an object is following a curved path, and by definition the centripetal acceleration is always positive. On the other hand acceleration can have a positive or negative radial component. Consider two electrons moving toward another, for example, with the origin at the center of mass. The radial component of acceleration will be positive because like charges repel.
Likes 1 person
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
