Chain rule for functions of operators?
8 replies · 6K views · last reply
pellman
This is strictly a math question but I figured that since it is something which would show up in QM, the quantum folks might be already familiar with it.
Suppose we have an operator valued function A(x) of a real parameter x and another function f, both of which have well defined derivatives.
consider [tex]\frac{d}{dx}f(A(x))[/tex]
Does this equal
[tex]\frac{df}{dA}\frac{dA}{dx}[/tex]
or
[tex]\frac{dA}{dx}\frac{df}{dA}[/tex]
or something else? Of course, if A and dA/dx commute, then either expression is good. But it is not clear to me that A and dA/dx would necessarily commute.
Fredrik said:
How do you define df/dA? (I don't think it's something we even want to define).
If f(u) is R --> R and has a Taylor series representation
[tex]f(u)=\Sigma \frac{1}{n!}f_n u^n[/tex]
where the f_n are just coefficients. Then
[tex]f'(u)=\Sigma \frac{1}{n!}f_{n+1} u^n[/tex]
We can similarly put
[tex]f(A)=\Sigma \frac{1}{n!}f_n A^n[/tex]
[tex]f'(A)=\Sigma \frac{1}{n!}f_{n+1} A^n[/tex]
For some f this may not work, it may not converge, blah, blah, blah. Let's just assume f is a function for which this works. The actual function I am interested in is [tex]f(A)=e^A[/tex], so f(A) = df/dA anyway.
Maybe I shouldn't be so general. My problem is this:
Suppose we have time-dependent Hamiltonian H(t). Then we can no longer write
[tex]|\Psi(t)\rangle = e^{-iHt}|\Psi(0)\rangle[/tex]
because dH/dt != 0 . What we need is an operator Q(t) such that dQ/dt=H .
Then we would have
[tex]i\frac{d}{dt}|\Psi(t)\rangle =i\frac{d}{dt}e^{-iQ(t)}|\Psi(0)\rangle[/tex]
[tex]=He^{-iQ(t)}|\Psi(0)\rangle[/tex]
or would it be
[tex]=e^{-iQ(t)}H|\Psi(0)\rangle[/tex]?
If H does not commute with Q, then the latter means we are not dealing with a solution to the Schrödinger equation. So what is
[tex]\frac{d}{dt}e^{-iQ(t)}=?[/tex]
(I wrote this before I saw your last post).
I think that's a directional derivative in the direction of A
[tex]\lim_{t\rightarrow 0}\frac{f(A+t\frac{A}{\|A\|})-f(A)}{t}[/tex]
Both the df/dA notation and the f'(A) notation seem very inadequate for directional derivatives. You could use something like [itex]D_X f(A)[/itex] for the directional derivative in direction X, at A. Your df/dA would then be [itex]D_A f(A)[/itex]. However, when we take the derivate of exponentials, don't we always do it with respect to a parameter? For example, when we prove that A is self-adjoint if U=exp(itA) is unitary:
[tex]U^\dagger U=I[/tex]
[tex]U^\dagger=U^{-1}[/tex]
[tex]e^{-itA^\dagger}=e^{-itA}[/tex]
Now apply [tex]\frac{d}{dt}\bigg|_0[/tex] to both sides, and we're done.
Added after I read your post #4: If Q(t) commutes with Q(s) for all t and s, then Q'(t) commutes with Q(t) and therefore with exp(iQ(t)), so the two options are equivalent. I need to think about the possibility that Q(t) doesn't commute with Q(s).
If your A is either self-adjoint or unitary in a (rigged) Hilbert space, then you can easily define a function f(A) by the means of the spectral decomposition of A. Then you can compute a derivative, but, of course, under tight conditions of convergence.
I don't think there are any simple formulas in this case. Note e.g. that d/dt Q(t)2=Q'(t)Q(t)+Q(t)Q'(t). So if we try to apply d/dt to each term of the exponential, things are already weird in the second order term.
I see what you mean. Darn. I was hoping this would have a simple answer.
Umm,... how does this work when one is dealing is a continuous family of operators
such as A(t) ?
E.g., for a given time, we have an operator [itex]A_0 = A(t=0)[/itex], (assumed to self-adjoint, say),
then we can spectral-decompose in terms of its eigenvalues and eigenstates:
[tex] f(A_0) ~=~ \int da_0 f(a_0) |a_0\rangle \langle a_0| ~~.[/tex]
But each A(t) will have a different set of eigenvalues and eigenstates in general,
[tex] f(A_t) ~=~ \int da_t f(a_t) |a_t\rangle \langle a_t| ~~.[/tex]
so how does one take the t derivative of the LHS without first computing
the time-dependent eigenvalues and eigenstates explicitly?
(Or did I misunderstand you?)
