Challenging integral involving exponentials and logarithms
  • Level: Graduate
  • Thread starter Thread starter Steve Zissou
    Insight Integral
14 replies · 5K views · last reply
Steve Zissou
TL;DR
This is harder than it seems.
Hi friends,
Can anyone offer some insight into this challenging integral?
I can't seem to think my way through this.
Thank you
Stevesie
$$ \int_{0}^{\infty}\frac{1}{x}\exp\left(-\frac{1}{2}\left( \frac{\log\left( x \right)-\mu}{\sigma}\right)^{2} \right)\exp\left(-\frac{1}{2}\left( \frac{ x -\alpha}{\beta}\right)^{2} \right)dx=??? $$
Your integral appears to be related to problems involving probability distributions, particularly those involving the product or convolution of different distributions.
Is that what you're working on?
Have you looked it up in a book of integrals?
Can you say what this integral is from?
It's actually related to some statistical Mechanics issues I'm working on, thanks
You're kidding, right? Ha ha
Right on, baby
No. Why would you think I am kidding?
What have you found from your query here? https://www.wolframalpha.com/
Looks like Wolfram Alpha can't do it, nor are there any published tables anywhere that have been helpful. That's why I'm enlisting the help of my friends here. Any ideas would be warmly appreciated.
You may have to do it numerically, or use some approximations. Are the values of alpha, beta, mu and sigma completely arbitrary, or do you have some prior knowledge of what they are? For example, for alpha = 5, beta = 0.5, mu=4.0, sigma=1.0, the second term (the Gaussian) is much narrower than the first term with the log. So you could approximate the first term with a linear function. Then the integral is easy. But this depends on the values of the constant terms. If they are completely arbitrary, it would be pretty easy to build a numerical function that will return the value of the integral given the four constant terms.
Thank you phyzguy! I think you've go the right idea. Still, it seems strange to me that such familiar functions haven't been examined in this way before.
I'm not clever enough to evaluate your integral:$$I=I\left(\alpha,\beta,\mu,\sigma\right)\equiv\intop_{0}^{\infty}\exp\left[-\frac{\left(\log x-\mu\right)^{2}}{2\sigma^{2}}\right]\exp\left[-\frac{\left(x-\alpha\right)^{2}}{2\beta^{2}}\right]\frac{dx}{x}\tag{1}$$but I do want to point out that the change-of-variable ##x=e^{y-y_{0}+\mu}## converts it to:$$I=I\left(\varepsilon,y_{0},\sigma\right)=\intop_{-\infty}^{\infty}\exp\left[-\frac{\left(y-y_{0}\right)^{2}}{2\sigma^{2}}\right]\exp\left[-\frac{\left(e^{y}-1\right)^{2}}{2\varepsilon^{2}}\right]dy\tag{2}$$where ##\varepsilon\equiv\beta/\alpha## and ##y_{0}\equiv\mu-\log\alpha##. I still can't do the integral in this form either, but it does have the advantage of depending on only 3 parameters rather than 4, and is pretty straightforward to compute numerically for any choice of those parameters.
Also, eq.(2) is reminiscent of integrals that appear in the literature for so-called Normal Log-normal Mixture (NLM) distributions. For example, see: http://repec.org/esAUSM04/up.21034.1077779387.pdf, eq.(4) for a somewhat similar integral. Alas, the author states that the analytical form of it too is "unknown", but does say that the integral can be "readily evaluated...either by simulation or by numerical integration".
Thank you, renormalize! I am familiar with that somewhat cryptic paper. Also I have been mostly unsuccessful in finding more discussion out there of the NLM distribution. Anyways I like your substitution which sets aside one parameter, that's nice. It's the darn double-exponential that seems to be the sticky wicket!
Update:
I found this paper: "The Convolution of the Normal and Lognormal Distributions," Hawkins, South African Statistical Journal (1991) 25, 99-128
In the paper, Hawkins presents the problem as I did, but also using the transformation suggested by @renormalize . Then Hawkins goes on to say, "...neither representation gives a standard well-known integral, and so both must be evaluated numerically..."
LOL!
Anyways I thought previously along the lines of @phyzguy above, imagining that we could collapse the lognormal part into a Dirac Delta, which would work out nicely. I brought this up in a different thread here (I don't know how to link to that thread - it's entitled "Dirac Delta: Normal -> Lognormal".) Of course @renormalize gave an extremely helpful insight there. Unfortunately this approach has not panned out. I need all parameters involved to be arbitrary, not a limiting case.
So, here we are. I really believe this integral can be worked out with pencil and paper - the final form of which would be some expression involving cumulative normals (Erf's) and so on. But my intuition just isn't cutting it.
Thanks all for your generous help.
