Change in entropy in a polytropic process
11 replies · 11K views · last reply
ricof
A piston cylinder device contains 1.2kg of nitrogen at 120kPa and 300K. Gas is compressed slowly in a polytropic process during which PV^1.3 = constant. The proces ends when the volume is reduced by one half. What is the entropy change?
(P2/P1) = (V1/V2)^n
Assuming V1 = 1 and therefore V2 = 0.5, I have worked out P2 as 295.5kPa but I am stuck on what to do next.
I should add that I have absolutely no idea where or how the 1.2kg of nitrogen comes into the equation, nor if V1 is in fact 1.
Please help me I've been staring at this one for hours!
How many moles is 1.2kg of nitrogen?
(P2/P1) = (V1/V2)^n
You can get V1 from the ideal gas equation. The 1.2 kg will come in handy there.
For entropy change, a useful relation is dQ/T = dS.
Oh right ok so
120kPa x V = 1.2 x R x 300K
As the gas is Nitrogen do I still use R=8.314?
ricof said:
Oh right ok so
This looks wrong. Where does this equation come from, and what does the 1.2 represent here? Include units with all quantities, and ask yourself if the units are what the should be.
No, use R = 8.314 Pa*m^3 / (mole*K). "8.314" is not the same thing.
In your previous post you mentioned the ideal gas law which is PV=nRT no?
n is the number of moles so I think you use the mass of the nitrogen (1.2kg) in there somewhere?
Yes, you use PV = nRT.
n is the number of moles of nitrogen, not the mass of nitrogen. You have to figure out how many moles there are. See Mapes's post #4
The atomic weight of nitrogen is 7 but as it is diatomic, the molecular weight is 7x2 = 14.
So 1.2kgs represents 1200/14= 85.7 moles = n?
