Change in pressure of a gas inside a tube
The discussion revolves around a U-shaped tube containing mercury, gas, and water, where a mass of another fluid is added, affecting the pressure of the gas. Participants are tasked with determining the change in pressure of the gas based on various parameters, including the density of mercury and the change in height of the mercury column.
  • Participants discuss the relationship between the pressures before and after the addition of the fluid, with attempts to reconcile their calculations with a provided solution. Questions arise regarding the definitions of pressure variables and the impact of height changes on pressure calculations.
Some participants are actively re-evaluating their definitions and calculations, noting discrepancies between their results and the given answer. There is an ongoing exploration of the effects of height changes on pressure, with some guidance offered on re-examining assumptions.
Participants mention constraints related to the definitions of pressure and the effects of fluid dynamics in the U-shaped tube, as well as the challenge of reconciling their results with the expected solution.
lorele
A U-shaped tube of uniform section "S" has one extreme closed and the other one open to the atmosphere. The tube contains mercury (M) in the central part, a gas (G) to the left that exerts a pressure "p" and a column of water (W) of height h_w to the right. Then, a mass "m" of another fluid of unknown density is poured over the right side and, when equilibrium is reached, the level of mercury on the left has risen "\Delta h", and the pressure of G is now p'. Determine the increase of pressure p'-p of G according to the density of mercury (\rho_m), \Delta h, S and m.
The given solution is p'-p={mg}/S - 2 \rho_m g \Delta h .
2. Homework Equations
p=\rho g h
krrk
p'=p_{water} + p_{mercury} + p_{air}=\rho_w g h_w + \rho_m g h_{mercury} + p_{air}
p=p_{water} + p&#039;_{mercury} + p_{air} + p_{new}=<b>\rho_w g h_w + \rho_m g (h_{mercury}+\Delta h) + p_{air} + {mg}/S </b>
p&#039;-p={mg}/S + \rho_m g \Delta h
[/B]
Your question presumably has to do with the difference between your answer and the given answer?
Yes, I don't know how to get the actual answer.
You'll want to re-examine your definitions and uses of "p ′ " and "p."
I can't edit the first post, so I made a new one. I swapped p' and p, but I think it's OK now. Still, I can't get the answer, and I don't know where I went wrong. Also, as the pressure increases with a decrease of height (that is, the change of height is actually negative), I changed the pressure of mercury in the second case to h-\Delta h, and I got somewhat closer to the solution, albeit without the 2, which I don't know where it comes from.
A U-shaped tube of uniform section "S" has one extreme closed and the other one open to the atmosphere. The tube contains mercury (M) in the central part, a gas (G) to the left that exerts a pressure "p" and a column of water (W) of height h_w to the right. Then, a mass "m" of another fluid of unknown density is poured over the right side and, when equilibrium is reached, the level of mercury on the left has risen "Δh", and the pressure of G is now p'. Determine the increase of pressure p'-p of G according to the density of mercury (ρm), Δh, S and m.
The given solution is p′−p=mg/S−2ρmgΔh.
p=ρgh
3. The Attempt at a Solution
p=p_{water}+p_{mercury}+p_{air}=ρ_w g h_w+ρ_m g h_{mercury}+p_{air}
p&#039;=p_{water}+p&#039;_{mercury}+p_{air}+p_{new}=\rho_wgh_w+\rho_mg(h_{mercury}-\Delta h)+p_{air}+{mg}/S
p′−p=p_{water}-p_{water}+p_{air}-p_{air}+p&#039;_{mercury}-p_{mercury}+mg/S=\rho_mg(h_{mercury}-\Delta h)-ρ_m g h_{mercury}+mg/S=mg/S-\rho_mg\Delta h
... and, the level of mercury on the right has _________?
been reduced by -\Delta h :biggrin:. OK, thanks!
  • · Replies 22 ·
