Change of kinetic energy problem
12 replies · 3K views
marjuna
Hi Forum :)
This is not a specific homework problem, just something I tried to solve myself.
A 10 kg object is moving at 10 m/s.
The object is losing 2v^2 J of kinetic energy per second.
Determine the time it takes for the speed to decrease from v_1 = 10 m/s to v_2 = 5 m/s.
EDIT: or even better, how do I obtain an expression for velocity as a function of time?
[tex]KE=0.5*m*V^2[/tex]
Alright, so the difference in kinetic energy between v_1 and v_2 is -375 J. I also noticed that the derivative of KE with respect to v is -2v^2. I somehow need to get the time variable in there.. How do I continue to solve the problem? I'm not interested in a numerical answer, more in the way of doing it.
Thanks in advance!
welcome to pf!
hi marjuna! welcome to pf! :wink:
you have d(mv2/2)/dt = 2v2 …
ok, now separate the variables :smile:​
Thanks tiny-tim!
So you get:
d(mv2/2)/dt = -2v2
d(mv2/2) = -2v2 dt
integrate both sides: d(mv2/2) was -375 J
-375 = -2v2*t
Uhm, how exactly do I continue from here?
oooh, sorry
write it as:
1/(-2v2) * d(mv2/2) = dt
THEN integrate both sides right?
But how do I integrate with respect to mv2/2 when the variable on the left side is just v?
two ways:
i] treat v2 as the variable, intead of v
ii] write d(v2) = 2v dv :wink:
Okay, then:
case i]
Write 1/(-2v2) * d(mv2/2) = dt as
1/(-4v2/m) d(v2) = dt
Then integrate the left side from v_1 to v_2 (substitute values) and the right side becomes t, obviously and then you've got an answer, right?and if you go for ii] then the equation becomes:
m/-2v dv = dt
and then also integrate both sidesbut one of them must be wrong since i get different expressions after integrating.. hmm
no, d(v2)/v2 = d(ln(v2)) …
try substitution if you can't see it immediately :smile:​
Uhm, I don't get it :(
How do you get rid of the m/2 inside d(mv2/2) so you're left with just d(v2)?But if you do it the other way:
write d(mv2/2) as mv dv..
then the equation becomes m/-2v dv = dtis that correct? oh man I really should start polishing up those calculus skills :)
well, yes, you do have to keep the m/2 also
that's right! :smile:
and now integrate …​
:smile: Alright then!
After integration the equation becomes:
t = -m/2 * ( ln[v_2] - ln[v_1] )
Substituting, m = 10 kg, v_1 = 10 m/s and v_2 = 5 m/s gives t ≈ 3.47 s
Seems plausible, right?
Alright then.
tiny-tim, thank you a lot for your time and help, I really appreciate it :biggrin: I hope you have a great day!
