Change of Variable With Legendre Equation
The discussion revolves around a change of variable in the Legendre equation, specifically transforming the independent variable from x to θ using the substitution x=cosθ. Participants are tasked with showing how the original equation transforms under this substitution.
  • Participants discuss the transformation of derivatives and the resulting form of the Legendre equation. There are questions about the presence of a factor of 2 in front of the cotangent term and the correctness of derivative calculations. Some participants express uncertainty about their own calculations and seek clarification on the application of the product rule.
Several participants have provided feedback on each other's calculations, particularly regarding the differentiation process. There is an ongoing exploration of the correct application of calculus rules, with some participants acknowledging mistakes in their reasoning. The discussion remains active with attempts to clarify misunderstandings.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is an emphasis on understanding the transformation process and ensuring the accuracy of mathematical operations involved.
Bassa
[/B]
Change the independent variable from x to θ by x=cosθ and show that the Legendre equation
(1-x^2)(d^2y/dx^2)-2x(dy/dx)+2y=0
becomes
(d^2/dθ^2)+cotθ(dy/dθ)+2y=0
2. Homework Equations
[/B]
I did get the exact form of what the equation should become, but I had a 2 in front of the cotθ term. I was wondering if the answer that the book provides is missing a factor of 2 in front of the cotθ term?
No, there shouldn't be a "2" factor there.
Thank you very much for your reply! I have spend many an hour trying to figure out where the 2 goes, but that was to to avail. I have the following:
(dy/dx)=(dy/dθ)(-1/sqrt (1-x^2))=(dy/dθ)(-1)(sin(θ))^(-1)
Can you please direct me to where I went wrong on the above statement?
Thanks!
The problem lies elsewhere. Show your calculation of ##(1-x^2)y''##.
Thanks for your reply! Here is my calculation for (1-x^2)y'':
(d^2y/dx^2) = (d^2y/dθ^2)(1-x^2)^(-1) = (d^2y/dθ^2)(1-(cosθ)^2)^(-1)
(1-x^2)y'' = (1-(cosθ)^2)(d^2y/dθ^2)(1-(cosθ)^2)^(-1) = (d^2y/dθ^2)
Differentiate the result you got for y'.
$$\frac{d^2}{dx^2}y = \frac{d}{dx} y' = -\csc\theta \frac{d}{d\theta} y' = -\csc\theta \frac{d}{d\theta} \left(-\csc\theta \frac{dy}{d\theta}\right)$$ You need to use the product rule.
I do have that in my solution and it leads to the earlier reply I posted. It also leads to the correct first term of the right answer. Is the following correct?
-csc(θ)(d/dθ)[y] = (cscθ)^2(d^2y/dθ^2)
No, that's not correct. As I noted earlier, you have to use the product rule. The ##d/d\theta## on the left acts on everything to its right.
Thank you very much! Sorry for the late reply, but I had to sleep on it. It worked perfectly fine! I was inventing my own incorrect rules for calculus, and that did not work very well!
P.S. I was wondering how you were able to type those derivatives very clearly. It is much more clear than having slashes and asterisks?
Thanks a lot!
  • · Replies 18 ·
