Undergrad Evaluating the integral in spherical coordinates - how to do it correctly?
The integral to evaluate is ##\int d^3 p \ \exp(i \vec{p} \cdot \vec{x}) / \sqrt{|p| + m^2}## over all of ##\mathbb{R}^3##, which can be transformed into spherical coordinates. The correct expression in spherical coordinates is ##\int dp \ d\varphi \ d\theta \ p^2 \exp(i \vec{p} \cdot \vec{x}) / \sqrt{|p| + m^2}##, with the limits for ##p## being from 0 to infinity and for angles ##\varphi, \theta## from 0 to 2π and 0 to π, respectively. The volume element in spherical coordinates includes a factor of ##\sin\theta##, and the denominator should be corrected to ##\sqrt{|p|^2 + m^2}##. Additionally, the scalar product ##\vec{p} \cdot \vec{x}## depends on the angle ##\theta##, necessitating the orientation of the coordinate system accordingly. The discussion highlights the importance of accurately setting up the integral in spherical coordinates for proper evaluation.
Tio Barnabe
I should evaluate ##\int d^3 p \ \exp(i \vec{p} \cdot \vec{x}) / \sqrt{|p| + m^2}## over all ##\mathbb{R}^3##. How can I do this in spherical coordinates? Since ##\vec{p}## is a position vector in ##\mathbb{R}^3##, our ##\vec{r}## of the spherical coordinates would be just equal to ##\vec{p}##, correct? (The same would be said of ##\vec{x}##, which we could call an ##\vec{r'}##.)
So the integral above would be re-written as ##\int dp \ d\varphi \ d\theta \ p^2 \exp(i \vec{p} \cdot \vec{x}) / \sqrt{|p| + m^2}##. I suppose that the correct range for our "spherical variables" is ##p \in (-\infty, \infty)## and ##\varphi, \theta \in [0, 2 \pi]##. Now the integral would then become ##4 \pi \int dp \ p^2 \exp(i \vec{p} \cdot \vec{x}) / \sqrt{|p| + m^2}##. How do I evaluate it?
EDIT: I don't need to give the final result, just to evaluate the last integral a little further.
No, in spherical coordinates your volume element is $$dV=r^2\sin\theta d\theta d\phi,$$
so you are missing a factor of ##sin\theta##. Also ##p## will be ##p=|\vec{p}|##, so the limits are ##p\in (0,\infty)##. Furthermore, your range for ##\theta## should be ##\theta\in [0,\pi]##. I also believe that in your initial expression the denominator should be ##\sqrt{|p|^2+m^2}##, if now ##m## is a mass. Notice, also that the scalar product depends on ##\theta##. You orientate the coordinate system so that ##\vec{p}\cdot\vec{x}=px\cos\theta##.
Likes Tio Barnabe
