Characteristic function of the binomial distribution
8 replies · 18K views
fluidistic
Hey guys, I'm self studying some probability theory and I'm stuck with the basics.
I must find the characteristic function (also the moments and the cumulants) of the binomial "variable" with parameters n and p.
I checked out wikipedia's article http://en.wikipedia.org/wiki/Characteristic_function_(probability_theory), apparently the solution is [itex](1-p+pe^{it})^n[/itex] though I didn't really understand what t stand for (number of successes?).
Characteristic function: [itex]\int e^{ikX} P(x)dx[/itex].
I'm guessing that I must simply apply the given formula. The k would be wikipedia's t variable. I'm stuck at finding P(x) and X. I've searched and found out the binomial distribution's article in wikipedia and [itex]P(K=k)=\frac{n!p^k (1-p)^{n-k}}{k!(n-k)!}[/itex] which is called the probability mass function. I don't know how how I could "plug" this into the given formula.
Thanks for any tip.
The definition of the characteristic function of a random variable X is
[tex]E[e^{ikX}][/tex]
How you calculate this expectation depends on what kind of random variable you are dealing with.
The equation you listed is for a continuous random variable, i.e. one that has a probability density function.
For a discrete random variable, with probability mass function P(X = n), the characteristic function would be
[tex]E[e^{ikX}] = \sum_{n} e^{ikn} P(X = n)[/tex]
Thanks for any tip.
First tip: do more than consult Wikipedia. Get a good *book*.
Anyway, the characteristic function of the Binomial random variable [itex]X[/itex] is
[tex]\text{ch}_{X}(t) \equiv E\left(e^{iX}\right) = \sum_{k=0}^n {n \choose k} e^{i t k} p^k (1-p)^{n-k} \\<br /> = \sum_{k=0}^n {n \choose k} (pe^{it})^k (1-p)^{n-k} = (1-p + pe^{it})^n,[/tex]
using the binomial expansion
[tex](a+b)^n = \sum_{k=1}^n {n \choose k} a^k b^{n-k}.[/tex]
The "t" has nothing to do with numbers of successes, or anything; it is just a parameter used in the characteristic function.
RGV
Ok thank you very much guys.
By the way which book(s) would you recommend me? Because I'm totally stuck at finding the moments (I know they are the coefficients of the Taylor's expansion of the characteristic function and the cumulants which are just the logarithm of the moments). Should I just calculate the Taylor's series of [itex](1-p + pe^{it})^n[/itex] with respect to t? Is this the way to go?
Some news about my tries:
The n'th moment around the point "a" is definied as [itex]\mu _ n (a)=\sum (x-a)^n P(x)[/itex] where P is the probability mass function.
So if I take the binomial distribution where there is N tries with each a probability of "p" to occur, then [itex]\mu _ N (a)= \sum _{k=1}^{N} (x-a)^N {N \choose k} p ^k (1-p)^{N-k}[/itex].
I'm sure I've messed up some variables here. I'm kind of confused. Any help is appreciated.
It is a bit easier to use the moment-generating function (mgf) instead of the characteristic function. The mgf of any discrete random variable X is
[tex]m_X(t) = \sum_{x} p(x) e^{tx} = E\, e^{tX}.[/tex] To get moments of X about 'a', you need to find [itex]E(X-a)^k[/itex], and the easiest way is to use
[tex]m_{X,a} (t) \equiv E\, e^{(X-a)t} = \sum_{x} p(x) e^{(x-a)t} = e^{-at} m_X(t).[/tex]
We have
[tex]E\,(X-a)^k = \left. \left( \frac{\partial}{\partial t}\right)^k m_{X,a}(t)\right|_{t=0}.[/tex]
For the binomial B(n,p) we have [itex]m_{X,a}(t) = e^{-at} (1-p + pe^t)^n.[/itex] For 'a' different from the mean the computation of the kth moment gets complicated (but do-able) for k > 2.
RGV
We have
RGV
I've had my second class in this course, the professor helped us a bit for this exercise.
He uses a different notation than in this thread; to get the first moment I think he chose your way (let me know).
From the characteristic function [itex]\phi _X (k)=(pe^{ik}+1-p)^N[/itex], one gets the moments via the formula [itex]<X^n>=\frac{1}{i^n} \frac{d^n}{dk^n} \phi _X (k) \big | _{k=0}[/itex]. (*)
Where in my case [itex]X=n_1[/itex] where [itex]P_N(n_1)=\frac{N!}{n_1!(N-n_1)!}p^{n_1} (1-p)^{N-1}[/itex]. So in a way I think he expect us to use the formula (*) where our "a" would be 0. Is there a link with the moment generating function you suggested to use?
I'm wondering if I can get a general expression for the nth derivative of the characteristic function. I'll work on this.
That formula is the same one I use, but in a different variable (k instead of t). The reason I use the moment-generating function instead of the characteristic function is just to avoid the annoying factor 1/i^k in front. As to a link: just Google "moment generating function", which turns up numerous articles.
RGV
Some news about this. I've found the first 2 moments (I used the formula in my previous post) and I'd like to find the first 2 cumulants.
What I've done so far is [itex]N \ln (pe^{ik}+1-p)=\sum _{n=1}^{\infty } C_n \frac{(ik)^n}{n!}[/itex]. I'm stuck here. I know I want [itex]C_1[/itex] and [itex]C_2[/itex] but I don't know how to proceed; at all. Any tip is welcome.
