Charge Density and Neuronal Cells-Help
5 replies · 6K views
deenuh20
Charge Density and Neuronal Cells--Help!
The cell membrane if a typical nerve cell consists of an inner and outer wall separated by a distance of 0.10 µm. The electric field within the cell membrane is 7.0 x 105 N/C. Approximating the cell membrane as a parallel plate capacitor, determine the magnitude of the charge density on the inner and outer cell walls.
E=charge density/Eo
Q=charge density*Area
I tried doing this problem by using E=Charge density/Eo and just solving for charge density. I'm not really quite sure how to find the area to use in the equation (I know its cylindrical, but I'm not sure how I can find the area with just the distance)
Thank you!
Well using the first equation rearrange for charge density because that's all that is asked for. You know the E-field and epsilon nought is a constant. It is however a very crude approximation as the cell is more cylindrical than anything else and the gap is not a vacuum.
That is what i did. I solved for charge density by the equation derived in my textbook for cylindrical approximations and got 1.239x10^-5 C/m^2 when using the equation, Charge Density = E*2Eo. However, when I type this answer in (it's online homework), it keeps saying it is incorrect, which is making me wonder if I am missing something??
The question states treating it as a parallel plate capacitor not a cylindrical one. For a parallel plate the charge density will be half the value you have obtained.
Nevermind, I got it, FINALLY!
I had to solve for Q using E=k*(Q/r^2) then find Area and solve for charge density by Q/A.
