Charge on capacitors each with a battery
The discussion centers on calculating the charge on three capacitors (C1=8.9 μF, C2=20 μF, C3=12.2 μF) connected to batteries with voltages V1=18 V, V2=10 V, and V3=18 V. The charges on the capacitors at equilibrium are q1=0.000121 C, q2=0.000287 C, and q3=0.000166 C. Key insights include the application of Kirchhoff's circuit law and the importance of recognizing that V1 and V2 are in series, resulting in a total voltage of 28 V for calculations. The conservation of charge principle is crucial for deriving the relationships between the charges on the capacitors.
  • Understanding of Kirchhoff's circuit laws
  • Knowledge of capacitor configurations (series and parallel)
  • Familiarity with the equation V = Q/C for capacitors
  • Concept of charge conservation in electrical circuits
  • Study the application of Kirchhoff's laws in complex circuits
  • Learn about series and parallel capacitor combinations
  • Explore the implications of charge conservation in electrical circuits
  • Investigate the effects of varying voltage sources on capacitor charging
Students studying electrical engineering, physics enthusiasts, and anyone looking to deepen their understanding of capacitor behavior in circuits.
reset_7
Three capacitors C1–C3, all initially uncharged, are placed in the circuit shown. The capacitances are C1=8.9 μF, C2=20 μF, C3=12.2 μF, and the battery voltages are V1=18 V, V2=10 V, V3=18 V.
What is the magnitude q1 of the charge on capacitor C1 once equilibrium has been established? Answer (given but I can't get it on my own): 0.000121 C
What is the magnitude q2 of the charge on capacitor C2 once equilibrium has been established? Answer (given but I can't get it on my own): 0.000287 C
What is the magnitude q3 of the charge on capacitor C3 once equilibrium has been established? Answer (given but I can't get it on my own): 0.000166 C
Potential across each pair of battery / capacitor is the same.
Equate the potential gain / drop from each branch to one another. But only get two equations (third is redundant) and have three unknowns.
Thanks in advance for any help.
Use conservation of charge.
ehild
Hey,
What I did to work through this problem was to first determine which way the currents were going from the sources and then write an equation based on Kirchhoff's circuit law for the current distribution. From there you can rewrite the capacitors in their appropriate forms (series or parallel equivalents) and start solving for variables.
The one thing that had me caught up for quite some time was what the total voltage was... pay close attention to the circuit diagram.
Cheers
ehild
Thanks for this message ehild, can you give me a bit more detail on the steps I would need to do in order to get the final solution?
Thanks again
Rtjones said:
Hey,
Cheers
Thanks RTjones. I have tried this but am still not getting the answer. Did you get the final answers?
Thanks again for any further help you can provide.
Yes I did get the correct answers. What I ended up doing to get the correct answer was using the EQn V = Q/Ceq. Where Ceq is the correct form for capacitance and Q is the total charge (which is subsequently the charge on capacitor 2). The part that was tripping me up though was that V is 28, not 18 or 10...the reason being because V1 and V2 are in series.
Using this V with the equation above you can solve for Qtotal (aka Q2) and then work your way back to the other charges via relating different paths to one another. Let me know if you're still struggling, I'd be glad to help...
Thanks again
You can change the position of the third battery with capacitor 3, it will not alter the voltages. If the upper plates of all capacitors are connected, no charge can flow on them, so the sum of charges on the three plates is zero. On the plates, the individual charges can be either positive or negative. If the capacitors are charged to Q1, Q2, Q3, respectively, there is -Q1 charge on the right plate of C1, +Q2 on the upper plate of C2 and -Q3 on the upper plate of C3. See picture.
ehild
Ok, thanks again for your help.
ehild
Thanks, it was that fact that the charges must add up to zero due to plates being connecged that gave me my third equation.
14K
