Charge on two suspended metal balls
  • Thread starter Thread starter crowdedscience
    Balls Charge Metal
The discussion centers on calculating the charge on two suspended metal-coated foam spheres, each with a mass of 2.80x10^-6 kg, that are hung from nylon threads 45 cm long and given equal negative charges. The spheres create an angle of 15 degrees with the vertical, leading to a misunderstanding of the geometry involved, as the configuration is an isosceles triangle rather than an equilateral triangle. The correct approach involves resolving forces in both x and y directions and utilizing the formula Q=√((Fr^2)/k) with k=9x10^9 N m²/C². The final charge calculated should be 6.66x10^-9 C, highlighting the importance of accurate geometric interpretation and force resolution in electrostatic problems.
  • Understanding of electrostatic forces and Coulomb's law
  • Knowledge of free-body diagrams and force resolution
  • Familiarity with trigonometric functions and their applications in physics
  • Basic principles of mechanics, including mass and gravitational force calculations
  • Study the principles of Coulomb's law and its applications in electrostatics
  • Learn how to effectively draw and analyze free-body diagrams
  • Explore the use of trigonometric functions in physics problems
  • Investigate the differences between isosceles and equilateral triangles in geometric problems
Students in physics, particularly those studying electrostatics and mechanics, as well as educators looking for examples of problem-solving in these areas.
crowdedscience
Two very small metal coated foam spheres, each of mass 2.80x10^-6kg, are attached to nylon threads 45cm long and hung from a common point. When the spheres are given equal quantities of negative charge, each supporting thread makes an angle of 15 degrees with the vertical. Find the charge on each sphere.
F=(kQ1Q2)/r^2 in the form of Q=√((Fr^2)/k) as Q1 and Q2 will be the same.
F=ma
probably Pythagoras and sine/tangent/cosine ratios
ok, so r or the distance between the charges was pretty obvious. If the strings are 0.45m long and the angle at the point where the strings combine is 30° (2x15°), then its going to be an equilateral triangle so r=0.45m (I think). I suppose we are assuming k=9X10^9. Noe for the force. The force of gravity will be 2.80x10^-6x9.8 (F=ma), which equals approximately 2.7x10^-7. I then did (2.7x10^-7)/tan(90-15), which equals about 7.4x10^-8. I thought that equaled half the force of repulsion of the sphere, but I'm not sure. If that's right then the total force of repulsion is 1.5x10^-7. So then
Q=√((1.5X10^-7x0.45^2)/9x10^9). That equaled 1.8X10^-9. But the actual answer is 6.66X10^-9. I know my rounding is having quite and effect on it, so i did it again, using as many decimals as I could but I was still quite a bit off. What am I doing wrong?
An equilateral triangle has angles of 60° - this one has a top angle of 30°.
oh wow, oopsies!
I don't really understand your solution attempt here.
Start by drawing a free-body diagram for one of the charges and resolve the forces along the x and y directions.
You should be able to eliminate the tension leaving only 1 unknown ( the charge ).
crowdedscience said:
... angle at the point where the strings combine is 30° (2x15°), then its going to be an equilateral triangle so r=0.45m
First and foremost, when did you learn that an equilateral triangle has an angle 30°? It's not an equilateral triangle!
This one will be isosceles!
Next why are you taking the weight as it is? Take its horizontal components!
Then I don't get why you are dividing by tan75°. Could you explain that?
Rookie mistake. You are unworthy of this forum. Next time go to yahoo answers...
12K
