Charging an Insulator: Explained
  • Context: High School
  • Thread starter Thread starter ArielGenesis
    Charged Insulator
The discussion focuses on the charging of insulators, specifically through the triboelectric effect, where rubbing materials like a glass rod with cat's fur transfers electrons, resulting in opposite charges. This process is influenced by the surface chemistry of the materials involved, particularly their electronegativity. Additionally, it highlights that insulators can be charged through exposure to radioactive beta decay, UV light, or X-rays, which can eject electrons via photoelectric interactions. The conversation clarifies that while the photoelectric effect is commonly associated with metals, it can also occur in insulators under specific conditions.
  • Understanding of the triboelectric effect
  • Basic knowledge of surface chemistry and electronegativity
  • Familiarity with the photoelectric effect
  • Concept of electron behavior in insulators
  • Research the triboelectric series and its implications for material charging
  • Explore the principles of surface chemistry in electrical applications
  • Study the photoelectric effect in insulators and its energy requirements
  • Investigate the effects of radiation on insulator charging mechanisms
Students in physics, materials scientists, electrical engineers, and anyone interested in the principles of electrostatics and material interactions.
ArielGenesis
I feel so ashamed to ask a question this simple, but how does an insulator get charged? Let's say rubbing a glass rod with cat's fur. I thought that insulator means there is no free electron.
Does rubbing means turning the neutral atoms at the surface of the glass rod into ions?
or something else is happening?
Yep, electrons are pretty much stripped off the surface of the insulator and transferred to the other object. Touching the two together forms a chemical bond, and if the surface chemistry is just right (e.g., one material has a higher surface electronegativity than the other one), then pulling them apart will result in an imbalance, leaving the surfaces charged with opposite polarities. When you rub the two together, you are essentially repeating this process many times over. It's called the triboelectric effect.
aha ic, so its surface chemistry, there were chemical reaction
these things were never taught in high or first year physics, no wonder i don't understand at all.
thanks
Also, if you have a strong radioactive beta-decay source near an insulator, betas can inbed themselves in the insulator and charge it up. In addition, visible or UV light or X-rays, through photoelectric interactions, can eject photoelectrons from the surface. In all these cases, because there is no conduction band in the insulator, the charges cannot be neutralized.
I thought photoelectric effect only happens in metals?
Insulators have a higher work function than metals, meaning it takes a higher energy photon to knock off an electron, but even insulators have electrons. The photons probably have to be vacuum-ultra violet (100 nm or shorter wavelength).
[Added edit] We also know that in the x-ray region, deep core photoejection (a form of photoelectric effect) can knock k-shell electrons out, which may escape the insulator. Outer electrons will then fill the k-shell, and leave a hole in the valence band. But since there are no electrons in the conduction band, the hole is not filled.
oooh ic thanks every1
  • · Replies 39 ·
  • · Replies 36 ·
