Why is Bremstrahlung or K-shell emission necessary in an x-ray machine?
The discussion centers on the necessity of Bremsstrahlung and K-shell emission in x-ray machines. It is established that x-rays primarily result from Bremsstrahlung due to rapid electron deceleration in the anode, particularly with a Tungsten anode (Z=74), while Molybdenum (Z=42) produces more characteristic x-rays. The potential difference between the anode and cathode is insufficient to generate significant radiation, as the acceleration involved is orders of magnitude smaller than that occurring at the atomic level. The Larmor formula, which describes the total radiated power as a function of acceleration, is also referenced.
  • Understanding of Bremsstrahlung radiation
  • Knowledge of K-shell emission in x-ray production
  • Familiarity with the Larmor formula for radiated power
  • Basic principles of electron acceleration in x-ray tubes
  • Research the Larmor formula and its derivation
  • Study the differences in x-ray production between Tungsten and Molybdenum anodes
  • Explore quantum mechanical effects in electron acceleration
  • Investigate the impact of anode composition on x-ray emission characteristics
Physicists, radiologists, and engineers involved in x-ray technology and radiation physics will benefit from this discussion, particularly those focused on optimizing x-ray machine performance and understanding radiation mechanisms.
AndresPB
Good morning all, I was just wondering the following question. When an electron is accelerated it emits electromagnetic radiation, depending on how much it is accelerated the energy varies so the frecuency does and the electromagnetic wave emitted would be of different colors or maybe even x-rays if the velocity is high enough. If this happens inside an x-ray machine, then why is it neccesary for the process of Bremstrahlung to occur? or K-shell emision? Would the electron alone be enough to generate x-rays or it is enough and the other fenomena occur only to generate more of them?
In an X-rays tube depending on the composition of the anode X-rays are mainly the result of Bremsstrahlung production due to the rapid deceleration of the electrons or the emission of characteristic X-rays due to the excitation of the atoms in the anode from the electron beam. Thus a Tungsten anode (Z= 74) produces mostly Bremsstrahlung while an anode of Molybdenum (Z=42) will have a larger percentage of characteristic X-rays.
The acceleration of the electrons due to the potential difference between the anode and cathode is insufficient to produce significant radiation.
Totally awesome thanks, how can i do a fast estimation of why the accelaration due to the potential diference is insufficient?
The acceleration in bremsstrahlung happens within the size of an atom. The acceleration between the electrodes happen within centimeters, the acceleration is about 9 orders of magnitude smaller.
Classically the rate of radiation emitted in an acceleration varies as the acceleration squared. In the case of a typical X-ray tube the anode cathode distance is a couple of centimeters while the distance it take an electron to decelerate in an anode say of Tungsten is a small fraction of a millimeter.
Thanks a lot, could you put the formula?
total radiated power = (2/3)(e2/c3)a2 in the Gaussian unit system.
Where e is the electronic charge
c is the velocity of light
a is the acceleration
Thanks a lot, where can i read about its deduction?
Google "Larmor formula"
That would be all thanks, you are the best. Just to get all clear, could you explain why is the distance important here? Is it because the desaceleration/aceleration happen faster when distances are short so they have to be bigger? It doesn't matter one happens via bremstrahlung and the other happens for a potential diference?
Right.
You can see the acceleration around an atom as potential difference as well - just with much higher field gradients. Well, quantum-mechanical effects can become relevant there, but let's ignore them for now.
  • · Replies 17 ·
