Charged sphere and charged conducting shell
9 replies · 3K views
pedro97
A + q = 5 pC charge is uniformly distributed on a non-conducting sphere of radius a= 5 cm , which is placed in the center of a spherical conducting shell of inner radius b = 10 cm and outer radius c = 12 cm. The outer conducting shell is charged with a -q charge. Determine:
1) the charges on the inner and outer surfaces of the shell;
2) the electric field (module, direction) everywhere;
3) the electrostatic potential on the external surface of the conducting shell (r = c), on the internal surface of the shell (r = b) and on the outer surface of the internal sphere of radius a (r = a).
Suppose now to replace the inner sphere with a spherical conductor of radius a charged with the same + q charge:
4) Which of the previous answers will change and how?
5) Determine the potential everywhere;
6) Determine the capacitance of the spherical capacitor formed from the internal conducting sphere of radius a and the outer conducting shell;
7) If a proton (m = 1.67·10-27 Kg) starts from rest from the spherical conductor of radius a, which will be its speed when it hit the inner surface of the outer spherical shell?
So, I would like to know if my attempt to solve the problem is correct, and how can I continue it in the parts I didn't manage to solve...
Thank you!
on Phys.org
For the first point my reasoning is: since on the inner sphere we have a + q charge, because of the induction phenomenon, the inner surface of the outer shell has to "balance" that charge, and thus has a charge -q. Since the problem statement tells us that -q is the total shell charge, we know that there is no charge on its outer surface...
You can just integrate the E field using your data from (2).
My mistake - I read it as +5q instead of +q = 5pC.
I don't understand your attempt at 5). Looks more like an attempt at 6).
haruspex said:
Yes, but we're not told where to set the zero potential. The usual convention is to set that at infinity.
Yes, and that is where he should and can integrate the E field from. What's the problem?
The custom is to set potential to zero at infinity unless that is impossible - as with a charged wire of infinite length.
