Charging Time for RC Circuit with Capacitor and Resistor
9 replies · 3K views
RougeSun
A 1234. pF capacitor and a 5.6 × 106 ohm resistor are connected in series to 78. volts EMF. Approximately how long does it take the capacitor to become almost fully charged?
Vf=Vo(1-e^(-t/RC))
I'm not sure if the equation I'm using is correct. I know there is one that has Q in it but couldn't find it. If there is Q in it how do I link it to volts? Through C=Q/Z?
You can use the equation you have. Just think, what will the voltage across the capacitor be when it is fully charged?
Ahh..okay. But wouldn't Vo be 0?
Look at your expression. If V0 were zero, then the voltage would be zero at all times and the capacitor would never charge. Here, V0 does not represent the "voltage at time t = 0". It represents the constant emf provided by the battery. What happens to your expression if you let time t go to infinity?
Vf=Vo(1-e^(-t/RC))
The equation that I have is Vc(t)=Vs(1-e^-t/RC)
Where Vc is the voltage across the capacitor
Vs is the voltae of the supply
Hope this helps.
Now I have a question:
Im working with a signal generator RC circuit. And I am trying to work out t=RC to workout the voltage waveform across the capacitor with the above mentioned formula.
This is a very basic formula, but following a few of them in a textbook has thrown me.
eg.
100 k Ohm
0.001 mirco F
This is what is in the textbook
t=RC=(100k)(0.001mF)=100millisecond
Now to me this is should be
t=RC=(100000 Ohm)(0.000000001 F)=0.0001 sec
I seem to be missing a decimal place each time. Can someone help please?
This is correct as it stands.
1 mF (one millifarad) = 10-3F
1 μF (one microfarad) = 10-6F
Are you perhaps confusing the two?
The mF that I have in there is microfarad. I did not have the mu sign.
And as it is I don't get that value on the calculator.
I get 0.0001sec
I get 0.0001sec
Then you are correct and
is also correct. In your case the capacitance is in microfarads and in the other case the capacitance is in millifarads.
Thank you for your help.
What I have done was made a mistake where it should be mircosecond not millisecond.
