PatPwnt
- 83
- 0
Just use Visible Light waves to heat up. Wear all black and stand near the window and absorb the light.
BRYAN said:This is an article from 2003 and I was wondering if anyone had any experience with this type of equipment?
Web Exclusive--Electro Silica Announces New Water Heating Systems
Electro Silica has developed a new technology for heating and purifying water.
Electro Silica has announced that it has developed a new way for heating and purifying water. The company applies a new technology to water treatment, offering an
efficient water heater powered by a clean and renewable energy. It offers the ability to save water and energy using microwave technology.
How Do Microwave Water Heating Systems Work?
Mains water enters into the Electro Silica boiler as the user requires. The heating system will be controlled by taps, heating timing devices, or the demands of an industrial process. As a demand for water is made, the magnetron fires up and bombards it with microwaves. These microwaves excite the water molecules, providing heat to the required temperature. Water exits the unit into either the heating system or the hot water pipes.
The Chamber Design Is the Difference
The microwave continuous flow and linear water heater consists of a closed chamber into which microwaves at a frequency of 2,450 mhz are introduced via magnetrons. The water heater is characterized by a chamber of the truncated conical section with a concave base of stainless steel, wherein no adjacent sections are at right angles, thus preventing generation of refraction and diffraction waves.The base of the chamber serves as a reflecting dish to direct energy towards the silica-based flexible coil disposed against the chamber wall. The coil is a spiral led inside the chamber and is terminated to inlet and outlet glands. These allow for a continuous flow of water to pass through the coil in any direction, depending upon the application and/or the plumbing arrangements in which it is being used.
How Safe Is Electro Silica?
The water heater produces fewer emissions than a microwave oven or even a mobile phone, with no risks of explosions or carbon monoxide. It is equipped with a heating automatic control system, water temperature and level display, and temperature automatic control.
http://www.pmengineer.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2732,96706,00.html
UV is dangerous: it is ionizing and it causes cancer.the blob inc said:why not use uv-radiation not only could You heat air or water but you could also kill off germs and other such molds, bacteria, and perhaps viruses in one fail swoop.
