The discussion revolves around identifying the cheapest and healthiest food options for a diet, particularly for individuals living in constrained circumstances, such as out of a car. Participants explore various food items, their nutritional value, and practical considerations for cooking and storage.
Exploratory
Technical explanation
Debate/contested
Experimental/applied
Some participants suggest ramen noodles, brown rice, and canned tuna as affordable staples.
Others propose fruits like apples and bananas for their low cost and nutritional benefits, although some note that bananas may not store well.
Frozen vegetables are mentioned as a cost-effective option, but some participants argue that frozen food may not be suitable for those living in a car.
Eggs are highlighted for their nutritional completeness, except for Vitamin C.
Vitamin pills are suggested as a way to cover nutritional gaps when food options are limited.
There is a discussion about cooking methods, with some participants recommending portable stoves or electric kettles for boiling water and preparing simple meals.
Some participants express concerns about malnutrition and the limitations of relying on single food sources.
Raw peanuts and corn are suggested as alternatives for protein and carbohydrates, respectively, with a caution against relying on ramen for health.
There is mention of local grocery stores and farmers' markets as sources for fresh produce at reasonable prices.
Participants do not reach a consensus on the best food options, as multiple competing views are presented regarding what constitutes a healthy and affordable diet. There is also disagreement on the practicality of certain cooking methods and food storage options.
Participants express varying assumptions about living conditions, such as whether one has access to cooking facilities or refrigeration, which affects their food recommendations. There are also unresolved questions about the energy consumption of cooking devices in a car.
#1
haxtor21
46
What would be the cheapest and healthiest food one could eat everyday? What kind of diet would be the cheapest and healthiest to survive on without any repercussions?
Ramen noodles, white tuna, brown rice, ... ?
Buffets ?
Bananas are about the closest you can get to a single food that will keep you alive for a long time.
Whatever you go for though, you'll suffer some kind of malnutrition, no natural food supplies everything you need. In the 1800s explorers were sometimes found dead of starvation while surrounded by skinned rabbits - however much they ate they weren't getting enough of the fat soluble nutrients.
If you're allowed a few different foodstuffs, then rice, lentils and fresh veg of some description are about as basic as you can get away with for a prolonged period.
#5
Topher925
1,563
Frozen vegetables are a good way to go too. You can often buy a pound of mixed oriental or persian vegetables for a little over a buck a pound.
#6
Siv
Eggs. They are almost a complete food, except for Vitamin C.
The white is the most bio available protein and the yolk is a wonder store of nutrients.
#7
JaredJames
2,822
I think people should tailor responses to someone living out of their car. So frozen is out.
Vitamin pills would be your best bet to cover as much ground as possible, but so far as nutrition goes, rice is a good start.
(Based on a previous thread by the OP)
#8
Insanity
57
I would suggest fresh produce, both veggies and fruits. Farmer's market do sell them fairly inexpensive, and small groceries will too. We have a local grocery that has a good selection at good prices, and that is where my spouse and I get our produce almost exclusively.
Looked at your other thread haxtor21
Look at getting sternos, they are fairly cheap, and walmart/meijer should carry them in the camping or kitchenwares. They're commonly used to heat food that's being served, but I've used them camping as well. They're good as heat source, and while you can't really cook say a steak with it, you can boil water or heat canned soups with them. They'll burn for ~2 hours.
For actually cooking outdoors, portable propane burners for camping can be inexpensive. A single propane burner where the tank is the stand for the burner can be gotten for $20, and the tank will last 9 hours on low. Most can boil a quart of water in minutes. Both a sterno or propane stove are good enough to heat canned soups, sterno might cook eggs and pancakes. I still have some of the original gas tanks from my stove with fuel and they're years old. I've done over 300 days of camping, hiked 200 miles with them.
haxtor21, where abouts in Michigan are you? I also live in Michigan and might be able to give better suggestions knowing your whereabouts.
jarednjames; being he is in Michigan and its late October, keeping frozen food in a car won't be a problem in a 2-3 months. Actually keeping food from freezing might be a problem. Two winters ago -10 to -20F was common.
haxtor21
46
I live in madison heights, north of Royal Oak. Thanks for the suggestions.
So then i would be able to do ramen noodles and rice in that thing. Correct?
#10
Dembadon
88
Almonds are quite healthy and make a good snack. I'll sometimes put a small handful in some low-fat cottage cheese (which is also good for you).
Insanity
57
You are not far from my hometown, though its been over 10 years since I lived there, I can search around and ask people I know who still live around there.
Just read one of the sternos I have, and it says it maintains a constants heat output of 205F, to keep food above the FDA recommendations, but I recall a friend using one to cook dumplings he made while camping, though he used a wind shield to prevent the flames from being blown about.
I would still think cooking rice and noodles would work, but definitely heating soups.
#12
Insanity
57
Royal Oak Farmers Market, though given the season, might be closed.
These are the other stoves I was mentioning, probably better for actual cooking. You'd be surprise how long one canister will last too, for number of meal preparation, most of the time I never had it on for more then 15 minutes.
Do you have any experience in camping during the winter?
drizzle
58
Dates fruit.
#14
Insanity
57
Just tried to boil water with the one I had. I put a lid on the small pot, and made a wind shield out of tin foil to place around the entire sterno and pot holder. Digital cooking temp probe never got above 210F and the water had some slight bubbling, but not a true boil. Took at least 45mins for this, and while it be good for heat source and heating soup, probably not for effective cooking.
I was trying to find a Scout Shop within Madison Heights, because honestly they'd probably have everything for you at decent prices, google wasn't showing one.
Is there an Associated Grocer's store in your area? Around here, the AG stores use bananas as loss-leaders to get older customers in the store. Bananas don't store that well, which ensures more frequent shopping by people who rely on them for cheap, healthy fruit. It's one way that these smaller stores can fight the supermarkets. Good deal if you like bananas.
#16
Dasani123
Water or o2, lol
#17
Acuben
61
i agree with fruits.
you should get some peanuts for proteins too if you don't mind raw peanuts (its not like I know too well about nutrients)
avoid ramen if you want to stay healthy. I would get corn as alternative to rice if you are just having it for carbs.
IMO those small sized fastfood food aren't bad if you have it once in a while (not everyday) without fries and drinks :P I... don't know that's just me.
Get some multivitamins if you think you won't get a malnutrition
#18
Evo
Staff Emeritus
24,114
3,277
Haxtor what do you have for cooking? No kitchen? Do you have an electrical outlet? I need to know that before I can make food suggestions.
#19
Insanity
57
Was thinking that an electric kettle would be better, at least for just boiling water. Making raman should be fine, teas, powder soups and such. Could not cook in it, but be better for simply making hot or boiling water for foodstuff.
#20
haxtor21
46
The situation depends. If I manage to get a night job and move in with a roommate i will have a electrical outlet, otherwise I am going to be in my car for a few weeks or so.
Will this device suck up a lot of energy from my car battery?
I have 0 camping experience. Nexam.
#21
gravenewworld
1,129
27
Pho or tacos. And I mean real tacos, not ones with cheese, sour cream, etc.
#22
Evo
Staff Emeritus
24,114
3,277
During power outages, I rigged up a wire mesh over a three wick candle and heated food that way.
If you have a few dollars, go to a hardware store, get a metal grate, two cement blocks or bricks, something to burn and a little steel cup or pot. This is really all you need if you have a place were you can cook over an open fire (sterno is an open fire).
#23
Insanity
57
I was thinking the fact you mentioned having access for showers at the gym, using an outlet shouldn't create too much problem. The electric kettles do heat water quick, the one I have is 120v 60Hz 1000w, but has no amp listed. Would fit nicely in a backpack or duffelbag. After showering while brushing teeth or such, plug it in and you should have boiling water in 5-10 minutes, pour into a cup of soup mix and got something hot as you walk out. In order to use in your car, you'll need an adapter.
I believe Madison Heights city parks are open to all Madison Heights residents. State parks are different and usually require an annual fee, but as most city parks have bbq grills, using them to cook with shouldn't be an issue. Collecting firewood shouldn't be either, but you cannot cut down trees, live or dead, only collect fallen branches.
Sleeping in your car in the winter will be a challenge, you're effectively outside even with the car's limited insulation. Staying warm is a priority, and you can't have the car running to heat it, potential carbon monoxide poisoning. Burning a candle or anything similar will eat the oxygen unless you leave a window somewhat open. I've camp outside in Michigan winter, and unless you know what to do, I would not recommend doing so. I'm sure anyone else here who has done something similar would agree.
The South Oakland Shelter may not to far from you, it has programs to assist homeless families and individuals, I think one offers a week supply of food. I don't know how the programs specifically work. It is in Royal Oak, I suggest checking them out.
Code:
http://www.southoaklandshelter.org/
The Salvation Army stores around here do sell used clothing, and they do a color tag special each week, where a color is 50% off and then come Saturday evening the same color items are $0.59 with some exceptions. Inexpensive winter clothing a possibility.
#24
Proton Soup
223
Buffets ?
Suggestions.
if you can afford the buffet, then yes, i think that is your best option. get most of your calories in one meal, and keep some non-perishables like saltines and peanut butter to snack on. bananas are also cheap with decent calories and will keep several days at a moderate temp.
#25
Louise M
Avocados are nature's super fruit. They contain protein, calcium, magnesium, phosphorus, potassium, iron, some B vitamins,Vitamin A,Vitamin K as well as vitamin E, not to mention fat that your body needs as well. Then there is Omega-6 fatty acids and Omega-3.
Another cheap food is potatoes. You can get them for a few bucks for 5 pounds AND you can eat them raw. Just peel the potato and take a bite like you would an apple. It too has protein (about 7grams) Vitamin A, Vitamin C,Vitamin D,Vitamin E,Vitamin K,Thiamin,Riboflavin,Niacin,Vitamin B6, Folate, Iron,Magnesium,Potassium,Omega-3,Omega-6 and Calcium.
#26
Evo
Staff Emeritus
24,114
3,277
Potatoes are excellent, I couldn't eat them raw though.
#27
Andre
4,296
73
Oignons too, which can be eaten raw Rght here in the Netherlands oignons are about as cheap as potatoes.
This weekend, my wife will make ox-tail soup. It should be about the cheapest stew-meat available, but due to demand and limited supply (only one tail per critter) the prices are competitive with nicer cuts.
#29
Centaur
34
You can get some Moringa (Moringa oleifera) leaves, you just need to buy the tree, or some leaf powder. It is used in countries with malnutrition. That will keep you alive for a long time.
Other than that, seeds like Linseed (Flaxseed) or any superfood are packed with nutritions and some of them might even be cheap, depending on your location and the availability of the plant.
#30
hamster143
911
Subway/Quizno's/Chipotle. A single burrito or a footlong sub will provide all the nutrition you need for a day, and almost all the calories, at the cost of $150 to $200 a month. You will need to cut it in half, of course. Supplement with ramen noodles to 1500-2000 calories a day.
Speaking of Chipotle, in many places there are authentic Mexican hole-in-a-wall restaurants catering to day laborers & such, they will be cheaper than that.
