Understanding Trigonometric Transformations: Analyzing a Horizontal Translation
  • Thread starter Thread starter aisha
    Trig
The discussion focuses on the trigonometric function y=2cos(-1/2x + 90) and its transformation into y=2cos[-1/2(x-180)] - 3. Key points include the period being -4π, amplitude of 2, and a vertical displacement of 3 units down. The horizontal translation is clarified to be 180 units to the right, correcting an initial misunderstanding. Participants emphasize the importance of distinguishing between radians and degrees in trigonometric functions. Overall, the analysis of the function's transformations is deemed mostly correct, with a critical adjustment regarding the direction of the horizontal translation.
aisha
y=2\cos (\frac {-1} {2}x + 90 ) -3
I changed the original function to
y=2\cos [\frac {-1} {2} (x-180)] -3
period=-4pi
amplitude=2
max=-1
min=-5
range={y:-5<=y<=-1}
domain={x:XER}
vertical displacement 3 units down
horizontal translation 180 units left
We can't tell- there is no "x" in the original function.
aisha: do not confuse radians and degrees.
I don't think I am confused about radians and degrees some of my trig functions have radians in them so to make things simpler I convert to degrees but in this question i haven't done any converting that 90 is in degrees. :smile:
sorry I added the x in the original function.
Did i do this question correctly?
Yes, seems correct although I think the horizontal displacement is to the right.
If the original question had 90 in it, then you did it correctly except for the direction of the horizontal translation. If the original question had \frac{\pi}{2} in it, then the value of the horizontal translation is off too.
thanks so much the original question does have 90 degrees in it. You are right the horizontal translation should be to the right NOT LEFT! :smile:
  • · Replies 38 ·
  • · Replies 25 ·
  • · Replies 38 ·
