Checking the Orientation of an Integral on a Surface Bounded by a Sphere
  • Context: MHB
  • Thread starter Thread starter mathmari
    Integral Orientation
The discussion revolves around calculating a surface integral over a hemisphere defined by the equation \(x^2+y^2+z^2=1\) with the condition \(y \geq 0\). Participants explore the use of spherical coordinates and the implications of the orientation of the surface, specifically ensuring that the normal vectors point away from the origin. The conversation also touches on related exercises involving different surfaces and orientations.
  • One participant proposes using spherical coordinates to evaluate the integral, suggesting the parameterization \(x=\cos\theta\sin\phi\), \(y=\sin\theta\sin\phi\), \(z=\cos\phi\) with \(\theta, \phi \in [0, \pi]\).
  • Another participant suggests checking the orientation using the gradient vector field and the normal vector's direction.
  • There is a question regarding the sign of the partial derivative \(\frac{\partial{(z,x)}}{\partial{(\theta, \phi)}}\), with some participants debating whether it should be positive or negative.
  • Participants discuss the calculation of the normal vector at a point on the sphere and whether it points away from the origin, referencing the cross product of the parameterization derivatives.
  • One participant confirms that the normal vector's sign aligns with the coordinates, indicating the correct orientation away from the origin.
  • In a related exercise, participants explore the orientation of a different surface described by \(\frac{x^2}{4}+\frac{y^2}{9}=1\) and the conditions required for the normal vectors to point away from the \(z\)-axis.
  • Another participant suggests checking the orientation by ensuring the dot product of the normal vector and the vector to the point is positive.
Participants express uncertainty regarding the sign of certain derivatives and the implications for the orientation of the surface. There is no consensus on the correct interpretation of the orientation conditions for the integral, and multiple viewpoints on the calculations and their implications are present.
Participants acknowledge the need for clarity on the orientation of the surface and the implications of the normal vector's direction. The discussion includes unresolved questions about the correctness of specific mathematical steps and the conditions for orientation in different exercises.
mathmari
MHB
Hey! :o
I want to calculate $$\iint_{\Sigma}\left (ydy\land dz+zdz\land dx+zdx\land dy\right )$$ where $\Sigma$ is the surface that is described by $x^2+y^2+z^2=1$ and $y\geq 0$ and has such an orientation that the perpendicular vectors that implies have a direction away from the point $(0,0,0)$.
Do we use here spherical coordinates?
$$x=\cos\theta\sin\phi , \ y=\sin\theta\sin\phi, \ z=\cos \phi$$ Since $y\geq 0$ we get that $\theta, \phi\in [0,\pi]$, right?
We have that $$\iint_{\Sigma}(P dy\land dz+Q dz\land dx + Rdx\land dy)=\iint_D\left (P(x(\theta, \phi), y(\theta, \phi), z(\theta, \phi))\frac{\partial{(y,z)}}{\partial{(\theta, \phi)}}+Q(x(\theta, \phi), y(\theta, \phi), z(\theta, \phi))\frac{\partial{(z,x)}}{\partial{(\theta, \phi)}}+R(x(\theta, \phi), y(\theta, \phi), z(\theta, \phi))\frac{\partial{(x,y)}}{\partial{(\theta, \phi)}}\right )d\theta d\phi$$
where $$\frac{\partial{(y,z)}}{\partial{(\theta, \phi)}}=-\cos\theta\sin^2\phi, \ \frac{\partial{(z,x)}}{\partial{(\theta, \phi)}}=-\sin\theta\sin^2\phi, \ \frac{\partial{(x,y)}}{\partial{(\theta, \phi)}}=-\sin\phi\cos\phi$$
Therefore, we get \begin{align*}\iint_{\Sigma}\left (ydy\land dz+zdz\land dx+zdx\land dy\right )&=\iint_D\left (-\sin\theta\sin\phi\cos\theta\sin^2\phi-\cos \phi\sin\theta\sin^2\phi-\cos \phi\sin\phi\cos\phi\right )d\theta d\phi \\ & =\iint_D\left (-\sin\theta\sin\phi\cos\theta\sin^2\phi-\cos \phi\sin\theta\sin^2\phi-\sin\phi\cos^2\phi\right )d\theta d\phi\end{align*}
Is everything correct so far? How do we use the given information about the orientation? (Wondering)
Re: Integral - Oriantation
Just a suggestion, you can always check using a gradient vector field to see what happens at that point. Check for the normal vector. What signs and which direction do they point?
mathmari said:
Hey! :o
mathmari said:
$$\frac{\partial{(z,x)}}{\partial{(\theta, \phi)}}=-\sin\theta\sin^2\phi$$
Shouldn't that be $\frac{\partial{(z,x)}}{\partial{(\theta, \phi)}}=+\sin\theta\sin^2\phi$? (Wondering)
We have the coordinates $(\theta,\phi)$, with $\theta$ first.
The normal vector at some point $\mathbf r$ on the sphere is $\pd {\mathbf r}\theta \times \pd {\mathbf r}\phi$.
Is it away from the origin? (Wondering)
We have the following: \begin{align*}\frac{\partial{(z,x)}}{\partial{(\theta,\phi)}}&=\begin{vmatrix}
\frac{\partial z}{\partial \theta} & \frac{\partial z}{\partial \phi}\\
\frac{\partial x}{\partial \theta} & \frac{\partial x}{\partial \phi}
\end{vmatrix} =\begin{vmatrix}
0 & -\sin \phi \\
-\sin\theta\sin\phi & \cos\theta\cos\phi
\end{vmatrix} \\ & =0\cdot \cos\theta\cos\phi-(-\sin \phi)\cdot (-\sin\theta\sin\phi) \\ & =-\sin \phi\cdot \sin\theta\sin\phi \\ & =-\sin\theta\sin\phi^2\end{align*}
or not? (Wondering)
Do you mean that $\mathbf r=(\cos\theta\sin\phi, \sin\theta\sin\phi, \cos\phi )$ ?
Do we check this with the sign of $\pd {\mathbf r}\theta \times \pd {\mathbf r}\phi$?
We have that $\pd {\mathbf r}\theta \times \pd {\mathbf r}\phi=\sin\phi (x,y,z)$, which has the same sign as $(x,y,z)$, since $\sin\phi>0$ for $\phi\in[0,\pi]$, right?
(Wondering)
0 & -\sin \phi \\
or not? (Wondering)
Oh yes. (Blush)
We have that $\pd {\mathbf r}\theta \times \pd {\mathbf r}\phi=\sin\phi (x,y,z)$, which has the same sign as $(x,y,z)$, since $\sin\phi>0$ for $\phi\in[0,\pi]$, right? (Wondering)
Yep. (Nod)
I like Serena said:
Yep. (Nod)
Since $\pd {\mathbf r}\theta \times \pd {\mathbf r}\phi=\sin\phi (x,y,z)$ has the same sign as $(x,y,z)$, since $\sin\phi>0$ for $\phi\in[0,\pi]$, this means that we have an orientation such that the perpendicular vectors that implies have a direction away from the point $(0,0,0)$,right?
Therefore, we get the following:
\begin{align*}\iint_{\Sigma}\left (ydy\land dz+zdz\land dx+zdx\land dy\right ) & =\iint_D\left (-\sin\phi\cos\theta\sin^3\phi-\cos \phi\sin\theta\sin^2\phi-\sin\phi\cos^2\phi\right )d\theta d\phi \\ & = \int_0^{\pi}\int_0^{\pi}\left (-\sin\phi\cos\theta\sin^3\phi-\cos \phi\sin\theta\sin^2\phi-\sin\phi\cos^2\phi\right )d\theta d\phi\end{align*}
At an other exercise we have:
$\Sigma$ is the surface that is described by $\frac{x^2}{4}+\frac{y^2}{9}=1$ and $0\leq z\leq 1$ and has such an orientation that the perpendicular vectors that implies have a direction away from the $z$-axis.
Using cylindrical coordinates we have $\Sigma (\theta , z)=(2\cos\theta , \ 3\sin\theta, \ z)$ and so $\Sigma_{\theta}\times\Sigma_z=(3\cos\theta, 2\sin\theta, 0)$.
What should hold here so that we have an orientation so that the perpendicular vectors that implies have a direction away from the $z$-axis?
The perpendicular vector needs to be in the same general direction as the vector to the point, or rather, it needs to be in the same half space.
We can check by taking their dot product, which must be positive then. (Thinking)
So, we have to take the interval for $\theta$ in such a way so that $\Sigma_{\theta}\times\Sigma_z=(3\cos\theta, 2\sin\theta, 0)>0$ ? So, we take $\theta\in\left [0, \frac{\pi}{2}\right ]$, or not? (Wondering)
We should take $\theta$ such that $(3\cos\theta, 2\sin\theta, 0)\cdot (\cos\theta,\sin\theta,z)>0$. (Thinking)
Do you maybe mean $(3\cos\theta, 2\sin\theta, 0)\cdot (2\cos\theta,3\sin\theta,z)>0$ ?
If yes, we have the following:
$$(3\cos\theta, 2\sin\theta, 0)\cdot (2\cos\theta,3\sin\theta,z)>0 \Rightarrow 6\cos^2\theta+3\sin^2\theta>0 \Rightarrow 6>0$$ Which holds for every vlue of $\theta$, so $\theta\in [0, 2\pi]$, right? (Wondering)
Nope. I meant the dot product of the perpendicular vector with the vector to the point (x, y, z) where we have the perpendicular vector.
Although we have defined $x=2\cos\theta, \ y=3\sin\theta, \ z=z$ ?
$$(3\cos\theta, 2\sin\theta, 0)\cdot (\cos\theta,\sin\theta,z)>0\Rightarrow 3\cos^2\theta+2\sin^2\theta>0\Rightarrow \cos^2\theta+2>0$$ This holds for every $\theta\in [0, 2\pi]$, right?
Didn't we have $\Sigma_\theta\times \Sigma_z=(2\cos\theta, 3\sin\theta, z)$ instead? (Wondering)
The idea is that we calculate $(\Sigma_\theta\times \Sigma_z)\cdot \mathbf r$, where $\mathbf r$ is the vector to the point where we calculate the perpendicular vector $\Sigma_\theta\times \Sigma_z$.
Yep. (Nod)
Oh yes. You were right all along. :o
Great!
So, always the dot product must be positive, or not? To check if I understood it well:
We consider $\Sigma$ to be the boundary of the bounded space $D$ that is defined by $0\leq z\leq 1-x^2-y^2$ and has such an orientation that the perpendicular vectors have direction to the outside of the space $D$.
We use here cylindrical coordinates, or not?
So, $\Sigma (\theta , z)=(R\cos\theta , \ R\sin\theta, \ z)$. Then we have that $0\leq z\leq 1-R^2$.
The perpendicular vector is $\Sigma_{\theta}\times\Sigma_z=(R\cos\theta, \ R\sin\theta, \ 0)$. Then the dot product is equal to $$(\Sigma_{\theta}\times\Sigma_z)\cdot \Sigma=(R\cos\theta, \ R\sin\theta, \ 0)\cdot (R\cos\theta , \ R\sin\theta, \ z)=R^2>0, \ \forall \theta\in [0,2\pi]$$ So, $\theta\in [0,2\pi]$.
Is everything correct? (Wondering)
That depends on what we want to check.
We are currently assuming a convex region around the origin respectively the z-axis.
This is the case for a sphere around the origin respectively for an elliptic cylinder around the z-axis.
In such cases the dot product must be positive everywhere on the surface.
Moreover, we should not limit the range of e.g. $\theta$ because of it. Instead we should verify that it is satisfied for every $\theta$. (Nerd)
If these assumptions are not satisfied (not convex or not around the origin or an axis), we need a different way to check. (Worried)
I would recommend spherical since z is bounded by a sphere.
Shouldn't that be $D=\{(R\cos\theta , \ R\sin\theta, \ z) : 0\le R\le 1, 0\leq z\leq 1-R^2\}$ and $\Sigma (\theta , z)=(\sqrt{1-z^2}\cos\theta , \ \sqrt{1-z^2}\sin\theta, \ z)$? (Wondering)
Then we'll get a different perpendicular vector and dot product.
  • · Replies 29 ·
