Chi-squared fit with errors on both x and y
8 replies · 8K views · last reply
Malamala
Hello I have some data points which have errors on both x and y coordinates. I want to fit a straight line to them but I am not sure how to take the error on x into account. Normally, when I have just the error on y, I want to minimize $$\sum\frac{(y_{pred}(x)-y_{measured}(x))^2}{\sigma_y^2}$$
Can I just replace ##\sigma_y^2## with ##\sigma_x^2+\sigma_y^2##? The errors on x and y are not correlated. Thank you!
Dale said:
It is also called orthogonal distance regression.
Yes. You start with the obvious thing - a line y = mx + b, and you try and do a least-squares fit using the perpendicular distances between the points and the candidate line instead of the y-distances. Problem is that doesn't always get you a unique unbiased solution.
That's why you need to specify what you are looking for very carefully.
Even though this appears to be a drive-by posting, I'll make one more comment.
If you minimize a function of Δy only, it's clear what you are doing. If you minimize something like Δx2 + Δy2 it's not even guaranteed that you have a number with consistent dimensions: suppose y is temperature and x is time. What units would Δx2 + Δy2 even be in?
To get a well-defined answer, one needs to pose a much, much better defined question. And even then it may not exist.
Maybe if you standardize your variables you can avoid the issue with units? I understand that is one if the reasons for standardization.
What do you mean by this?
I was replying to @Vanadium 50 regarding his statement on mixed units in the expression ##\sqrt \delta x^2 + \ delta y^2 ##. If you standardize your expression ( assuming normality of data or other) the resulting variable is unitless , from algebra alone ( you're dividing two expressions with the same units ), so that you avoid at least this issue of having mixed units. Seems like something @Stephen Tashi may know about.
