Choosing the Right Voltage Gain for Frequency Amplification | 250 Hz to 50 kHz
The discussion revolves around determining the appropriate voltage gain for an amplifier to increase the frequency of an audio signal from 250 Hz to 50 kHz. Participants explore concepts related to amplification, frequency multiplication, and the implications of using ultrasonic frequencies.
  • One participant inquires about the necessary voltage gain for amplifying a signal from 250 Hz to 50 kHz.
  • Another participant suggests that without circuit details, it is difficult to provide assistance.
  • Some participants explain that transistors are commonly used for amplification but vary in their operating voltage range and input sensitivity.
  • There is a discussion about the feasibility of increasing frequency versus amplitude, with some participants asserting that voltage gain does not directly increase frequency.
  • Frequency multipliers are mentioned as a potential solution for achieving higher frequencies.
  • Concerns are raised about the potential dangers of high-frequency sounds, particularly regarding hearing damage.
  • Participants discuss the use of ultrasonic transducers and their frequency response, questioning the appropriateness of using a transducer designed for higher frequencies.
  • There is mention of mixing signals and the potential outcomes of such processes, with some skepticism about the usefulness of certain methods.
  • One participant expresses a strong desire to achieve the desired frequency despite the challenges and warnings presented by others.
Participants express differing views on the relationship between voltage gain and frequency increase, with some asserting that they are not directly related. There is no consensus on the best approach to achieve the desired frequency, and multiple competing views remain regarding the use of amplifiers versus frequency multipliers.
Limitations include the lack of specific circuit details and assumptions about the capabilities of transducers and amplifiers. The discussion also highlights the potential risks associated with high-frequency sounds and the need for careful consideration of hearing safety.
This discussion may be of interest to individuals exploring audio amplification, ultrasonic applications, and the technical challenges associated with frequency manipulation in electronic circuits.
Sveral
How do I know, how big of a voltage gain for an amplifier do I need, if I want to increase the input frequency from 250 Hz to 50 kHz?
Thank you.
Without knowing the details of your circuit I don't think we can help you.
The purpose any amplifier is to use a small voltage signal as an input and generate a higher voltage signal with the same waveform.
Generally transistors are used for this but transistors vary in their optimum operating voltage range, and they also vary for input sensitivity.
Transistors which can guarantee to efficiently/accurately amplify higher frequency input signals tend to be harder to make, and at very high frequencies they get expensive.
Thank you.
It is very unlikely that you would be building a circuit to do what you seem to be saying. Perhaps you could explain what you would like to achieve, then we can tell you how to go about it?
Not making any sense. Voltage gain does not increase frequency.
Ok, I want to increase the frequency of an audio source from 250 Hz to 50 kHz so I can hear it via inner ear...Roughly speaking...
There isn`t a circuit yet, because I don`t have nearly enough knowledge to build one yet, that`s why I want to know, how to go about it. I simply want to increase the frequency of an audio source from 250 Hz to 50 kHz so I can work with ultrasound, listen to it by using my inner ear.
Not going to argue, that`s why I`m here- to learn!
Do you want to increase frequency/amplitude?
Yes, just that-frequency.
Then there are something called as frequency multipliers
Thank you for the intel, any suggestions for one that would be relatively cheap and amplify the frequency 200x?
Yes, they are verily possible. We can double or triple frequency using some simple circuits. The doubled or tripled frequency signals can be used for various applications.
Take the case of microprocessors. A faster clock frequency(say twice or four times) means faster operation in sequential circuits.
But it is not much use of increasing frequency by 200 times( either for sine or square eaves).
Instead of increasing frequency from 250 Hz to 50Khz, you can generate 50KHz output itself.
The amplifier does not need a different gain for a different frequency. It needs a greater passband. Audio power amplifiers often have an ultrasonic filter to prevent parasitic oscillation in the output stage. That may block your 50kHz.
What type of transducer will you use? What is the frequency response?
To compensate for the frequency response of the transducer may need to change amplifier gain.
With 50kHz you will probably feel very irritated, but you will not perceive it as a sound.
How good were your ears. If you are not very careful you will probably damage your ears in the experiment.
I do have a 50 kHz square wave generator, it would be possible to mix it with the audio source, but what would happen to the frequency of the mixed signal?
But, can we really hear 50Khz? Is 20Khz, not the maximum frequency we can hear?
http://www.topqualitytools.co.uk/at...UH4lAyheqgLOQGEeq2dm9l1Fi69zGYIMpKRoCuNnw_wcB
That would be the tramsducer I have in mind, the inner ear should be able to perceive it as sound...I`m positive there is a way of getting this done and I will do so no matter how many people I have to ask for help...
What do you mean by the term "mixing"? does it mean voltage addition(adding function generator waveform and audio signal)?
You are correct, but the inner ear is something we have in common with dolphins and a few other species who can perceive ultrasound, so it should be possible.
No, I meant by using an audio mixer of sorts to combine the two signals and create a third one, just that the third frequency most likely won`t be at 50 kHz.
What do expect the third frequency to be?
I need a 50 kHz frequency, but I doubt that the third frequency will be such...
So, you want something like 50 Khz? If you want some mixing you can use the principles used in Amplitude modulation, where both the signals are multiplied. But, i doubt the usefulness of the method.
Leaving the circuit construction aside, how can you sense ultrasonic waves? Don't we need an ultrasonic sensor?
An ultrasound transducer can output sound in this frequency range and thus the inner ear can perceive it...Ok, then which one would you suggest a transistor amplifier or a frequency multiplier?
Is that transducer designed to operate at 50 kHz or at 1.65 MHz ?
30 W of ultrasonic near your ears will be dangerous.
I don't think you really know what you are doing. What do you actually want to do and why ?
30 W is too much, though. Some suggest that ultrasonic waves can be used to repel pests(including rats) but they also warn that higher power can damage humans too.
It`s designed to work up to 1.65 MHz, I intend to use it at 50 kHz...If you`ve heard about a neurophone, you`ll understand...
Hmmm let's compare cochleae...
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC389506/
In the dolphin Tursiops truncatus, the basilar membrane over its course its course from basal to apical ends shows a systematic variation in width and in the manner and rigidity of its suspension.
The suspension is by bony laminae on both the outer and inner edges in the basal region, and by progressively less rigid attachments in the more apical regions, until near the apex the membrane is held only by connective tissue.
The basilar membrane shows an unusual variation in width of 14 times, ranging from an astonishingly small value of 25 μm at the basal end to a value toward the apex of about 350 μm. This structural variation is in harmony with the extension of sensitivity of the dolphin ear into the very high frequencies, and suggests unusual capabilities of pitch discrimination in this high range.
human on other hand is
The parameters of the membrane at a given point along its length determine its characteristic frequency (CF), the frequency at which it is most sensitive to sound vibrations. The basilar membrane is widest (0.42–0.65 mm) and least stiff at the apex of the cochlea, and narrowest (0.08–0.16 mm) and most stiff at the base.[3] High-frequency sounds localize near the base of the cochlea (near the round and oval windows), while low-frequency sounds localize near the apex.
Not that different maybe , 3x in width ?
Before investing a lot of money, see whether you can hear that 50khz .
It will be interesting also to see whether you can hear short bursts of 50khz
when i was in high school a fellow built a 40khz sonar for science fair using a hi-fi tweeter and a parabolic dish to both send and receive. (All vacuum tubes of course in 1963...)
When he broadcast continuous tone for tuning it up one could not hear it
but when he switched into pulsed for ranging, wow was it annoying.
The guys are right - you want to amplitude modulate. Easiest way is just switch it on and off. A 555 timer's discharge pin could short the input to an audio ampilifier. If you use a LM386 it can't make enough power to hurt you.
I see same outfit you're looking at makes this gizmo
http://elcodis.com/parts/2881113/SRM400.html#datasheet
which already pulses the high frequency and that frequency is adjustable.
Have fun, be careful, and start with millliwatts.
Interesting !
https://neurophone.wordpress.com/2012/08/05/make-a-diy-flanagan-neurophone-with-a-tl494/
but i'd add a cap in series with transducer and connect both wires...
and set his TL494 for push-pull
see http://www.ti.com/lit/ds/symlink/tl494.pdf
Happy Experimenting !
@jim hardy...This is the first time am hearing neurophone but the concept is cool. Thanks OP.
  • · Replies 40 ·
  • · Replies 41 ·
