Solving Chromatography PDE with MOL and ode15s
The discussion focuses on solving a partial differential equation (PDE) using the method of lines (MOL) and the MATLAB function ode15s. The PDE models concentration and flow dynamics in chromatography, specifically addressing the equations for concentration C and flow q with given initial and boundary conditions. The user encountered issues with numerical stability, leading to non-physical solutions, likely due to incorrect discretization of the equations. The gradient matrices for the first and second derivatives were provided, along with a MATLAB implementation that includes a feed profile function and an isotherm model.
  • Understanding of partial differential equations (PDEs)
  • Familiarity with MATLAB and its ode15s solver
  • Knowledge of numerical methods, specifically the method of lines (MOL)
  • Experience with chromatography principles and isotherm models
  • Investigate numerical stability techniques for PDEs in MATLAB
  • Learn about advanced discretization methods for PDEs
  • Explore the implementation of different isotherm models in chromatography
  • Study the effects of boundary conditions on numerical solutions of PDEs
Researchers and engineers in chemical engineering, particularly those working with chromatography simulations, numerical analysts, and MATLAB users seeking to solve PDEs effectively.
msanx2
Hello all
I am using the method of lines to solve the following PDE:
## \frac {\partial C} {\partial t} + F\frac {\partial q} {\partial t} + u \frac {dC} {dz} = D_{ax} \frac{\partial^2 C} {\partial z^2} ##
## \frac {\partial q} {\partial t} = k (q^{*}-q) ##
With these initial conditions:
## C(0,z) = 0 ##
## q(0,z) = 0 ##
and boundary conditions:
## C(t,0) = C_{in} (1) ##
## \frac {\partial C} {\partial z}(t,L) = 0 (2) ##
I discretized the equations above in space and obtained a system of ODE's which I solved with ode15s. To deal with the boundary condition (2) I said:
## \frac{C(t,L+1) - C(t,L-1)}{2\Delta z}= 0 ## or ## C(t,L+1) = C(t,L-1) ##
The problem is that my system gives a solution which tends to explode and makes no sense. My guess is that the way I am discretizing the system is not correct or consistent. I am using between 50-150 nodes.
My gradient matrix for the 1st derivative (GM1) looks like:
\begin{bmatrix}
0 & \frac{1}{2} & 0 & 0 & 0 & 0 & 0 & ... & 0\\
\frac{-8}{12} & 0 & \frac{8}{12} & \frac{-1}{12} & 0 & 0 & 0 & ... & 0\\
\frac{1}{12} & \frac{-8}{12} & 0 & \frac{8}{12} & \frac{-1}{12} & 0 & 0 & ... & 0 \\
0 & \frac{1}{12} & \frac{-8}{12} & 0 & \frac{8}{12} & \frac{-1}{12} & 0 & ... & 0 \\
0 & ... & 0 & 0 & 0 & \frac{1}{12} & \frac{-8}{12} & \frac{-1}{12} & \frac{8}{12} \\
0 & ... & 0 & 0 & 0 & 0 & 0 & 0 & 1
\end{bmatrix}
and b1 = \begin{bmatrix}
-\frac{C_{in}}{2} \\
\frac{C_{in}}{12} \\
0 \\
0 \\
-C_{in}
\end{bmatrix}
For the 2nd derivative (GM2):
\begin{bmatrix}
-2 & 1 & 0 & 0 & 0 & 0 & 0 & ... & 0\\
1 & -2 & 1 & 0 & 0 & 0 & 0 & ... & 0\\
0 & 1 & -2 & 1 & 0 & 0 & 0 & ... & 0 \\
0 & ... & 0 & 0 & 0 & 0 & 0 & 2 & -2
\end{bmatrix}
and b2 = \begin{bmatrix}
C_{in} \\
0 \\
\end{bmatrix}
In the end I say that:
## \frac {\partial C} {\partial z} = \frac{1}{h}GM_{1} \cdot C + \frac{1}{h}b_{1}## and ## \frac {\partial^2 C} {\partial z^2} = \frac{1}{h^2}GM_{2} \cdot C + \frac{1}{h^2}b_{2}##
My code:
FUNCTION 1:
Code:
function [sol, t, x, C] = LDF_mol(isoType, feedProf, parameter, L, Di, epsb, Q, Cfeed, KLDF, Dax, tpulse, tfinal, opt)
% Transport-Dispersive Model (TDM) considering mass transfer resistance in the solid to be dominant and
% using the Linear Driving Force Model (LDF) approach (Glauckauf and Coates, 1947)
% Change the isotherm model by modifying the isotherm function
% Change feed profile between pulse (e.g.: chromatografic peak) and step (e.g.: breakthrough experiment)
% Multicomponent
% Uses pdepe functin to solve the system of partial differential equationsglobal data Grad1 Grad2 res Cs_col
%% Default arguments (Example)
if nargin == 0
    isoType =   'mod-langmuir';                                                     % isotherm type, can be 'linear' or 'linear-langmuir'
    feedProf =  'pulse';                                                            % feed profile, can be 'pulse' (e.g.: chromatografic peak) or 'step' (e.g.: breakthrough experiment)
    parameter = [1e3 0.3/1e3 0.05; 1e3 0.1/1e3 0.045];                               % isotherm parameters (depends on the isotherm model chosen)
    L =         10;        % cm, column length
    Di =        1;        % cm, column internal diameter
    epsb =      0.4;        % column bulk porosity
    Q =         4;        % mL/min, flow rate
    Cfeed =    [0.6*300/50 ; 0.6*300/50];                             % g/L, feed concentration
    KLDF =      [60; 60];                                                    % min-1, linear driving force (LDF) mass transfer coefficient
    Dax =       [6.57e-3; 7.57e-3];                                     % cm2/min, axial dispersion coefficient
    tpulse =    0.1;        % min, feed pulse duration. For a step injection set tpulse = tfinal
    tfinal =    5;        % min, final time for calculation
    opt.npz =   50;        % number of discretization points in z
    opt.npt =   100;        % number of discretization points in t
    opt.fig =   true;                                                               % true - show figures; false - do not show figures
    Cs_wash = 0; % Salt concentration in mM
    twash = 1;
    t0_elu = tpulse+twash; telu = 8; Cf = 80;
    Cs_elu = @(t) 0+(Cf-0)/telu*(t-t0_elu);
    Cs_reg = 80;
    treg = 3;
    Cs_eq = 0;
    teq = 3;
end
%% Calculations
addpath('../')
data = struct('isoType',isoType,'feedProf',feedProf,'parameter',parameter,'Cfeed',Cfeed,'Cs_wash',Cs_wash,'Cs_elu',Cs_elu,'Cs_reg',Cs_reg,'Cs_eq',Cs_eq,'npz',opt.npz,'npt',opt.npt,'Q',Q,'L',L,'epsb',epsb,'tpulse',tpulse,'twash',twash,'t0_elu',t0_elu,'telu',telu,'treg',treg,'teq',teq,'KLDF',KLDF,'Dax',Dax);
nc = length(Cfeed);
data.nc = nc;
A = pi()*Di^2/4; % cm2
data.F = (1-epsb)/epsb;
data.ui = Q/A; % cm/min
% Run MOL
t = linspace(0,tfinal,opt.npt);
z = linspace(0,L,opt.npz);
[Grad1,Grad2] = GradientMatrix(opt.npz);
u0 = zeros(2*nc*opt.npz,1);
[t,uout] = ode15s(@odefun, t, u0);
for CompNo = 1:data.nc
    idx1 = 1+(CompNo-1)*opt.npz; idx2 = CompNo*opt.npz;
    C{CompNo} = uout(:,idx1:idx2);
end
res.t = t'; res.z = z'; res.C = C;
Cs_col = zeros(opt.npt,opt.npz);
Cs_col(:,1) = Cs_profile(t);
for i = 1:eek:pt.npt
    for j = 2:eek:pt.npz
        if t(i)-z(j)/data.ui >= 0
            Cs_col(i,j) = Cs_profile(t(i)-z(j)/data.ui);
        else
            Cs_col(i,j) = 0;
        end
    end
end
ymat = [];
    ymat = [ymat C{CompNo}(:,end)];
end
[ax,h1,h2] = plotyy(t,ymat,t,Cs_col(:,1));
axis([0 tfinal  0 inf]) % fix the axes
set(ax(1),'Box','off'); set(ax(1),'YTick',0:0.2:2); set(ax(2),'YTick',0:20:100,'YLim',[0 100]);
xlabel('t')
ylabel('C')
% Concentration over time with slider figure
    figure
    hold all
    slidermin = 1; % t = 0
    slidermax = opt.npt; % t = tfinal
    ymax_aux = [];
    for CompNo = 1:data.nc-1
        res.hslider(CompNo) = plot(z',C{CompNo}(end,:));
        ymax_aux = [ymax_aux max(C{CompNo}(2,:))];
    end
    ymax_aux = [ymax_aux max(C{data.nc}(2,:))];
    res.ymax = str2double(num2str(max(ymax_aux),1));
    axis([0 L 0 2]);
    [ax,h1,h2] = plotyy(z',C{data.nc}(end,:),z',Cs_col(end,:));
    set(ax(1),'Box','off'); set(ax(2),'YTick',0:20:100,'YLim',[0 100]);
    hold off
    res.hslider(data.nc) = h1;
    res.hslider(data.nc+1) = h2;
    xlabel('Position, z')
    ylabel('Concentration, C')
    anno_text = sprintf('t = %.1f', 0);
    res.time_box = annotation('textbox',[.55 .48 .4 .5],'String',anno_text,'EdgeColor', 'none','FitBoxToText','on');
    sld = uicontrol('Style', 'slider',...
        'Min',slidermin,'Max',slidermax,'Value',slidermin,...
        'SliderStep',[1 1]./(slidermax-slidermin),...
        'Position', [390 390 120 20],...
        'Callback', @sliderplot);
%% Auxiliary functions
function sliderplot(source,event)
% Handles the UI slider in the Concentration vs Position plot
global data res Cs_col
val = round(get(source,'Value'));
    set(res.hslider(CompNo),'YData',res.C{CompNo}(val,:));
end
set(res.hslider(data.nc+1),'YData',Cs_col(val,:));
anno_text = sprintf('t = %.2f',res.t(val));
set(res.time_box,'String',anno_text);
function udot = odefun(t,u)
    nc = data.nc; npz = data.npz; L = data.L;
    z = linspace(0,L,npz); h = L/(npz-1);
    Cin = setFeedProfile(data.feedProf, t, data.tpulse, data.Cfeed);
    C = u(1:nc*npz);
    for CompNo = 1:nc
        idx1 = 1+(CompNo-1)*npz;
        C(idx1) = Cin(CompNo);
    end
    q = u(nc*npz+1:end);
    Cs = zeros(npz,1);
    udot = zeros(2*nc*npz,1);
    for j = 1:npz
        if t-z(j)/data.ui >= 0
            Cs(j) = Cs_profile(t-z(j)/data.ui);
        else
            Cs(j) = 0;
        end
    end
    qeq = isotherm1(data.isoType, C, Cs, nc, data.parameter);
    dCdz = zeros(nc*npz,1); d2Cdz2 = zeros(nc*npz,1);
    for CompNo = 1:nc
        idx1 = 1+(CompNo-1)*npz; idx2 = CompNo*npz;
        idx3 = npz*(nc+CompNo-1)+1; idx4 = (nc+CompNo)*npz;
        b1 = zeros(npz,1); b1(2) = -Cin(CompNo)/2; b1(3) = Cin(CompNo)/12;
        b1(end) = -C(idx2);
        b2 = zeros(npz,1); b2(2) = Cin(CompNo);
        dCdz(idx1:idx2) = Grad1*C(idx1:idx2)./h + b1./h;
        d2Cdz2(idx1:idx2) = Grad2*C(idx1:idx2)./h^2 + b2./h^2;
        udot(idx3:idx4) = data.KLDF(CompNo)*(qeq(:,CompNo)-q(idx1:idx2));
        udot(idx1:idx2) = -data.ui*dCdz(idx1:idx2) - data.F*udot(idx3:idx4) + data.Dax(CompNo)*d2Cdz2(idx1:idx2);
        udot(idx1)=0; udot(idx3) = 0;
    end
%% Feed profile
function Cinj=setFeedProfile(feedProf, t, tpulse, Cfeed)
% Defines the feed profile. Can be 'pulse' (e.g.: chromatografic peak) or 'step' (e.g.: breakthrough experiment)
if strcmp(feedProf,'pulse')
    if t<=tpulse
        Cinj = Cfeed;
    else
        Cinj = zeros(1,length(Cfeed));
    end
elseif strcmp(feedProf,'step')
    Cinj = Cfeed;
else
    error('Invalid feed profile. feedProf must be "step" or "pulse"')
end
function Cs_in = Cs_profile(t)
global data
Cs_in = zeros(length(t),1);
for i = 1:length(t)
    if t(i) <= data.tpulse
        Cs_in(i) = 0;
    elseif t(i) <= data.tpulse+data.twash
        Cs_in(i) = data.Cs_wash;
    elseif t(i) <= data.tpulse+data.twash+data.telu
        Cs_in(i) = data.Cs_elu(t(i));
    elseif t(i) <= data.tpulse+data.twash+data.telu+data.treg
        Cs_in(i) = data.Cs_reg;
    else
        Cs_in(i) = data.Cs_eq;
    end
end
function [Grad1,Grad2] = GradientMatrix(N)
Grad1 = zeros(N,N);
Grad1(2,2) = 1/2; Grad1(3,1:4) = [-8/12, 0, 8/12, -1/12];
Grad1(end-1,end-3:end) = [1/12 -8/12 -1/12 8/12]; Grad1(end,end) = 1;
for i = 4:N-2
    Grad1(i,i-3:i+1) = [1/12, -8/12, 0, 8/12, -1/12];
end
Grad2 = zeros(N,N); Grad2(2,1:2) = [-2, 1];
Grad2(end,end-1:end) = [2,-2];
for i = 3:N-1
    Grad2(i,i-2:i) = [1, -2, 1];
end
FUNCTION 2
Code:
%% Isotherm Library
function q=isotherm1(isoType, C, Cs, nc, parameter)
% Defines the isotherm
parameter = transpose(parameter); N = length(Cs);
q = zeros(N,nc);
Cmat = zeros(N,nc);
for i = 1:nc
    idx1 = 1+(i-1)*N; idx2 = i*N;
    Cmat(:,i) = C(idx1:idx2);
end
if strcmp(isoType,'mod-langmuir')
% Linear-Langmuir isotherm:   q1(C1,C2) = a1*b1*exp(-m1*Cs)*C1/(1+b1*exp(-m1*Cs)*C1) , parameter = [a1 ; b1 ; m1]
    for i = 1:N
        langmuirDenominator = 1;
        for j = 1:nc
            langmuirDenominator = langmuirDenominator +  parameter(2,j)*exp(-parameter(3,j)*Cs(i))*Cmat(i,j);
        end
        q(i,:) = parameter(1,:).*parameter(2,:).*exp(-parameter(3,:)*Cs(i)).*Cmat(i,:)/langmuirDenominator;
    end
else
    error('Invalid isotherm type. isoType must be "linear" or "langmuir" or "linear-langmuir"')
end
I think now I kind of solved it. However when the wave reaches the right boundary there is some noise in the wave. Do you know what could be the reason?
Code:
% Multicomponent
if nargin == 0
    parameter = [1e3 1.5/1e3 0.15; 1e3 2/1e3 0.045];                               % isotherm parameters (depends on the isotherm model chosen)
    tfinal =    8;        % min, final time for calculation
    opt.npz =   300;        % number of discretization points in z
    twash = 1;
    Cs_reg = 80;
    treg = 3;
    Cs_eq = 0;
    teq = 3;
end
%% Calculations
addpath('../')
nc = length(Cfeed);
data.nc = nc;
% Run MOL
end
for i = 1:opt.npt
    for j = 2:opt.npz
        else
            Cs_col(i,j) = 0;
        end
    end
end
ymat = [];
end
xlabel('t')
ylabel('C')
    figure
    hold all
    ymax_aux = [];
    end
    axis([0 L 0 2]);
    hold off
end
    C = u(1:nc*npz);
    for CompNo = 1:nc
    end
    Cs = zeros(npz,1);
    for j = 1:npz
        else
            Cs(j) = 0;
        end
    end
    for CompNo = 1:nc
        b1 = zeros(npz-1,1); b1(1) = -Cin(CompNo)/2; b1(2) = Cin(CompNo)/12;
        b1(end) = -C(idx2);
        b2 = zeros(npz-1,1); b2(1) = Cin(CompNo);
        dCdz(idx1) = 3.14; % Value does not matter
        d2Cdz2(idx1) = 3.14; % Value does not matter
        dCdz(idx1+1:idx2) = Grad1*C(idx1+1:idx2)./h + b1./h;
        d2Cdz2(idx1+1:idx2) = Grad2*C(idx1+1:idx2)./h^2 + b2./h^2;
    end
%% Feed profile
    if t<=tpulse
        Cinj = Cfeed;
    else
    end
    Cinj = Cfeed;
else
end
global data
for i = 1:length(t)
        Cs_in(i) = 0;
    else
    end
end
% Grad1 = zeros(N,N);
% Grad1(2,2) = 1/2; Grad1(3,1:4) = [-8/12, 0, 8/12, -1/12];
% Grad1(end-1,end-3:end) = [1/12 -8/12 -1/12 8/12]; Grad1(end,end) = 1;
% for i = 4:N-2
%     Grad1(i,i-3:i+1) = [1/12, -8/12, 0, 8/12, -1/12];
% end
Grad1 = zeros(N-1,N-1);
Grad1(1,2) = 1/2; Grad1(2,1:4) = [-8/12, 0, 8/12, -1/12];
for i = 3:N-3
    Grad1(i,i-2:i+2) = [1/12, -8/12, 0, 8/12, -1/12];
end
Grad2 = zeros(N-1,N-1); Grad2(1,1:2) = [-2, 1];
for i = 2:N-2
    Grad2(i,i-1:i+1) = [1, -2, 1];
end
  • · Replies 36 ·
