See a Complete Circle Rainbow: Causes & Conditions
  • Context: High School
  • Thread starter Thread starter damitr
    Rainbow
The discussion centers on the conditions and causes for observing complete circular rainbows, exploring both natural occurrences and specific scenarios that might allow for such visibility. Participants delve into the physics of light refraction and reflection in raindrops, as well as the observational perspectives required to see full circles.
  • Some participants note that natural rainbows typically appear as semicircles due to the horizon blocking part of the arc.
  • One participant asserts that all rainbows are circular, suggesting a misunderstanding of visibility versus shape.
  • Another participant proposes that the circular shape may result from light refracting through spherical raindrops, mentioning the complexity of the refraction process.
  • Conditions for seeing a complete circle include being at a high elevation or having water droplets close enough, such as from a garden hose.
  • Some participants reference observations from airplanes, where circular rainbows can be seen when flying into or out of rainclouds.
  • One participant discusses the angle of the rainbow, noting that it appears 42 degrees above the anti-solar point, and that visibility is affected by the sun's position relative to the horizon.
  • Another comment highlights that in areas with heavy mist and sunlight, a full circular rainbow can be visible, starting from the viewer's feet.
  • A participant reflects on the relationship between their shadow and the rainbow's center, questioning the accuracy of their observation.
Participants express multiple competing views on the conditions necessary for observing complete circular rainbows, and the discussion remains unresolved regarding the specifics of visibility and the physics involved.
Some claims depend on specific observational conditions, such as elevation and the position of the sun, which may not be universally applicable. The discussion also touches on the complexity of light behavior in raindrops, which is not fully resolved.
damitr
All the rainbows that appear naturally, are usually semicircles, what is the reason for this, they could also be as little arcs as well. Are there any conditions under which a complete circle of the rainbow may be seen?
Science news on Phys.org
all r circular even the ones made naturally
It could take that shape because the light is refracting from the insides of circular shaped raindrops? I know that the actual refraction through the raindrop is somewhat complicated (I think it is bent at 2 interfaces which seems to be why that upside down "2nd rainbow" with the reverse colors appears sometimes).
Stand high enough above the ground so that the horizon doesn't block the lower part of the rainbow. Or if the water drops are close enough to you.. try it with water from a garden hose that has a spray nozzle.
I haven't observed it myself, but I've seen photos taken from airplanes flying into or out of rainclouds and they can see a circular rainbow.
The arc of the rainbow is 42deg, thus any time the sun is below 20deg from the horizon you should be able to see more then a semi circle of the rainbow. In the future observe closely any evening rainbows you may encounter. I have personally observed this phenomena. It is also possible if the sun is high enough above the horizon to have no rainbow. This would occur in the summer at higher latitudes.
http://en.wikipedia.org/wiki/Rainbow#Physics_of_rainbows" says it better.
Normally, when you see a rainbow, you're seeing light that has been reflected from raindrops that are fairly distant, so they're practically all above the horizon from your point of view. If the light is reflecting off drops that are close enough that some of them are below the horizon, then you might see the rainbow extend below the horizon. Or if you're in a hilly or mountainous area, you can sometimes see a rainbow in front of the mountains or hills.
If the water droplets are both above and below you, such as viewed from aeroplane (as Kazza 765 points out), you will see a circular rainbow.
Elaborating on Integral's comment on position of the rainbow: from any surface elevation, the primary rainbow appears 42 deg above the anti-solar point or ray. A secondary rainbow can appear 51 deg above the anti-solar ray. So if you look at the same rainbow from a higher perspective, you will see the primary rainbow 42 deg up, relative to your new position.
"Rainbows are not seen in midday since the whole 42° circle is below the horizon at most latitudes. So rainbows tend to be seen most in the later afternoon when a thundershower has passed and the sun from the west is illuminating the receding edge of an eastwardly moving raincloud." (same ref)
If you are in somewhere where there is a heavy mist and the sun is shining you will see the rainbow in a full circle. It starts at your feet and goes out from there in a circular shape. You're standing at the end of a rainbow, start digging.
I was looking at a rainbow the other day and i noticed something that made sence
the sun is behind me
my shadow is in front
it looks like the center of the rainbow is where my eyes are on my shadow
i thought about that and it made sence
i was wondering if it was actually true
  • · Replies 18 ·
