Circuit analysis current source problem
4 replies · 2K views · last reply
Jamessamuel
given the circuit shown, find V1.
Hand-drawn circuit schematic with a 6A current source on the left pointing up, an 8 ohm resistor on top, a 40 ohm resistor below the top wire labelled with node voltage V1, an 80 ohm resistor in the middle, a 1 ohm resistor labelled 170 ohm on the right with node voltage V2, and a 1A current source on the right pointing down.
see image:
am i right? Video says otherwise... I chose to use the superposition theorem here.
Handwritten circuit analysis on lined paper using superposition: first a 6A source with 4Ω, 5Ω and 1Ω resistors and a 5Ω branch, then a 1A source with 4Ω and 5Ω resistors, with the calculations for V1 shown below.
help appreciated,
regards,
james.
[ ATTACH=full]91899[/ATTACH]
see image:
[ ATTACH=full]91898[/ATTACH]
help appreciated,
regards,
james.
That second image is very difficult to read.
It appears that you took the 80Ω and 120Ω to be a parallel combination, which is correct. However, that combination is NOT in series with the 8Ω resistor.
I think they're considered in series for getting the current through them when the 1A supply is ignored, but must be separated to get individual resistor voltage drops. Once all individual voltage drops are gotten they are then combined (superpositioned?) for the answer.
Jamessamuel said:
surely this is correct?
[ ATTACH=full]91916[/ATTACH]
That's fine for the 6A source.
There is a different parallel/series combination you need to use for the 1A source. For this, there is no 56Ω combination.
(Thanks, insightful.)
Added in Edit:
The above refers to the following:
Handwritten circuit schematic on lined paper: a resistor of 8 at the top, with 40, 80 and 120 resistors and a 1A current source in parallel below, plus handwritten equations 40 I1 = 56 I3 and I3 = (40/56) I1.
The 40Ω and 8Ω are in series.
That combination and the other two resistors, 80Ω and 120Ω, are all in parallel with the other.
