Circuit Elements: Battery, Resistors & Capacitor Charge 195μs Post Switch Open
The discussion focuses on a circuit with three resistors and a capacitor connected to a battery, analyzing the charge on the capacitor 195 μs after the switch is opened. Participants clarify that the capacitor is fully charged initially, but the voltage across it after the switch opens is determined by the series combination of R2 and R3, not the battery voltage. The equation used for calculating the charge, Qmax(1-e^(t/CR)), is debated, with emphasis on the need to consider the correct resistance and voltage across the capacitor. It is suggested to use the Thevenin equivalent for the resistors to simplify the analysis. The conversation highlights the complexities of capacitor discharge in circuits with multiple resistors.
deerhunt713
Three resistors and a capacitor are in a circuit with a battery:
R1 = 23 Ω
R2 = 13 Ω
R3 = 15 Ω
C = 6.2 µF
V = 17 V
The switch has been closed for a long time. What will the charge be on the capacitor 195 μs after the switch is opened?
https://online-s.physics.uiuc.edu/cgi/courses/shell/common/showme.pl?courses/phys212/fall09/homework/06/11_paired/image.gif
WHat are your thoughts on the matter? Is this a charging or discharging capacitor 195 μs after the switch is opened? What are the relevant equations to describe this?
ok well the capacitor is fully charged, so the voltage of the capacitor is the same as the battery, from there i can find the max charge. then i used the equation Qmax(1-e^(t/CR))
where i used 28 for the resistance. but that's not giving me the right answer
Try again. The voltage across the capacitor is the same as across the series combination R2+R3. That's not the voltage across the battery. What is it?
That's not the only problem. The current through C is not the current through either R1 or R2+R3 so you can't use those in Qmax(1-e^(t/CR) either.
I recommend replacing V, R1, R2 and R3 with their Thevenin equivalent.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
