Circuit Problem with Resistors connected in parallel and series
The circuit problem involves five resistors and a 12.0 V battery, with the current through resistor R4 being zero. This indicates that there is no voltage across R4, suggesting that the nodes connected to R4 are at the same potential. The user is struggling to visualize the circuit and how to break it down into series and parallel components for analysis. Clarification is provided that there are no opportunities to combine resistors as drawn, and the focus is on understanding the implications of I4 being zero. The discussion emphasizes the importance of visualizing the circuit to solve for the current I1 effectively.
Souboro
A circuit is constructed with five resistors and a battery as shown. The battery voltage is V = 12.0 V. The values for the resistors are: R1 = 76.0 Ω, R2 = 149.0 Ω, R3 = 169.0 Ω, and R4 = 121.0 Ω. The value for RX is unknown, but it is known that I4, the current that flows through resistor R4, is zero.
Find I1
Resistors in Series
Req = R1 + R2
Veq = V1 + V2
Ieq = I1 = I2
Resistors in Parallel
Req = (1/R1 + 1/R2)^-1
Veq = V1 = V2
Ieq = I1 + I2
V = IR
I know this has been asked elsewhere, but I read the other threads and couldn't get anything that helped me from them. I think I'm just having trouble visualizing the problem, and breaking the circuits into parts. I guess I'm having a lot of trouble visualizing how the energy travels through the circuit.
I just can't picture it at all. I started by combining the circuits into R13, R4, and R2x. I'm guessing that for I4 to be zero, I14 has to equal I2. Ahh... If I can see this problem built once, I'm sure I could do it over and over again. Help please...
Find I1
Resistors in Series
Req = R1 + R2
Veq = V1 + V2
Ieq = I1 = I2
Veq = V1 = V2
Ieq = I1 + I2
V = IR
How did you combine things? There are no series or parallel component opportunities in the circuit as drawn.
Hint: If I4 is zero, what does that tell you about the potential across R4, and thus the potentials of the nodes that R4 connects to?
22K
